Urgos Grandfather Clock
Folkvisor
Hi All
I haven't been here for a while.
I'm working on an Urgos Grandfather Clock. The movement seems to be working fine but the clock isn't free-standing. It's in the middle of a China cabinet and there are no side access panels.
I am tempted to MAKE some with a chainsaw but, unfortunately, the owner doesn't like the idea.
Does anyone have any experience with such creatures?
Dave
Thank you for your answer. Yes it's a modern movement - about 30 years old.
I got it out - took almost an hour. Putting it back in will be even more of a challenge I think. It will only go out the back. I'm hoping I'll be able to fix the dial before putting it back in.
I'm just hoping everything will line up for the chime hammers. I marked everything before removing the movement but it doesn't seem to matter much. I think it's just a kind of hit and miss thing.
But after cleaning and oiling the clock works.
I got it in and it works. It was a LOT easier when I found out it came out the front of the case!!! After doing all kinds of other crap...
Anyway, it's in and working.
But I had a nice level clock shelf for it and it is now on a floor that isn't level so...whatever...
Thank you for your comments.
I found this to be necessary, if you want to find out more about Longcase clocks.
White Dial Clocks: The Complete Guide by Brian Loomes. Any book on clocks by Brian is worth every penny. Watch and clock makers of the world vol 1 and 2 are helpful in dating, comes in very handy if you  have to value clocks but very handy as reference books. Anything by Laurie Penman is worth having. Some of the books I had were very old must have been from around 1900 all out of print. I can write up for you how I would undertake repairing a longcase clock, if that would help you. Watch and clock supplies tend to stock more of the popular books.
I forgot these mags have a fantastic amount of information.
http://www.clocksmagazine.com/
I can second Oldhippy's recommendation of the clocks magazine.
I have a current subscription and it has some real gold in it, also if you are into social media Clocks Magazine also has a facebook group, but I tried to avoid Facebook myself even though I have an account
I am working on another Grandfather Clock.
I think it should come out the front if I can loosen - and later remove - the screws holding it on the saddle to move it back about 1/4 inch so the wooden face-plate can slide down and out. Taking the saddle off won't give it enough room to slide out and it is very awkward to get at it. There are also 2 screws in 2 brackets holding the movement in place on the pendulum side that need to be removed but I'm thinking they can be loosened and left in place until I can see my way clear to take the movement out.
I see no other way to do this safely.
Do you have any advice regarding my idea(s)?
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
