Urgos Grandfather Clock
Folkvisor
Hi All
I haven't been here for a while.
I'm working on an Urgos Grandfather Clock. The movement seems to be working fine but the clock isn't free-standing. It's in the middle of a China cabinet and there are no side access panels.
I am tempted to MAKE some with a chainsaw but, unfortunately, the owner doesn't like the idea.
Does anyone have any experience with such creatures?
Dave
Thank you for your answer. Yes it's a modern movement - about 30 years old.
I got it out - took almost an hour. Putting it back in will be even more of a challenge I think. It will only go out the back. I'm hoping I'll be able to fix the dial before putting it back in.
I'm just hoping everything will line up for the chime hammers. I marked everything before removing the movement but it doesn't seem to matter much. I think it's just a kind of hit and miss thing.
But after cleaning and oiling the clock works.
I got it in and it works. It was a LOT easier when I found out it came out the front of the case!!! After doing all kinds of other crap...
Anyway, it's in and working.
But I had a nice level clock shelf for it and it is now on a floor that isn't level so...whatever...
Thank you for your comments.
I found this to be necessary, if you want to find out more about Longcase clocks.
White Dial Clocks: The Complete Guide by Brian Loomes. Any book on clocks by Brian is worth every penny. Watch and clock makers of the world vol 1 and 2 are helpful in dating, comes in very handy if you  have to value clocks but very handy as reference books. Anything by Laurie Penman is worth having. Some of the books I had were very old must have been from around 1900 all out of print. I can write up for you how I would undertake repairing a longcase clock, if that would help you. Watch and clock supplies tend to stock more of the popular books.
I forgot these mags have a fantastic amount of information.
http://www.clocksmagazine.com/
I can second Oldhippy's recommendation of the clocks magazine.
I have a current subscription and it has some real gold in it, also if you are into social media Clocks Magazine also has a facebook group, but I tried to avoid Facebook myself even though I have an account
I am working on another Grandfather Clock.
I think it should come out the front if I can loosen - and later remove - the screws holding it on the saddle to move it back about 1/4 inch so the wooden face-plate can slide down and out. Taking the saddle off won't give it enough room to slide out and it is very awkward to get at it. There are also 2 screws in 2 brackets holding the movement in place on the pendulum side that need to be removed but I'm thinking they can be loosened and left in place until I can see my way clear to take the movement out.
I see no other way to do this safely.
Do you have any advice regarding my idea(s)?
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
