Tap and Die Kit
margolisd
Hi. I have a watch movement with stripped threads in a very tiny 0.4 mm screw hole. Is it best to fix this with a tap? Or at this miniature level is there another tool that would be more suitable? I've never used taps or dies but willing to invest in a kit. Can anyone recommend something not too expensive? I was also wondering if there was such a thing as a tap accessory for a jeweling tool or staking set. (Sorry if that's a stupid question, just that would seem to make sense in my head!) New to this so any advice appreciated :)
thats not a bad idea, something for the staking set that holds the tap - it would help with small tap breakage where not keeping it straight is the major cause.  Its very common with larger, but still small and breakable, size tapping jobs to use a tapping stand to avoid breaking them
As for tapping, that's a very small tap.   How do tap a stripped hole the same tap size - do you close it in or bush it, or go a size bigger and make a new screw?  .....as in if it is really stripped there won't anything left to tap....it maybe its just slightly damaged and needs to be chased/cleaned up?
Edited by measuretwice
Quote
Bergeon sold 4.7 mm punches with a set of collets. There are also collet holding arbors for Seitz jewelling tools, I have one in the big Seitz set.
Frank
I think a bigger screw is the way to go. If you closed it in I guess the wall of the screw hole would go from being strait to being curved in so less thread would make contact with the screw.
19 minutes ago, oldhippy said:
Just a standard soft solder and flux. You don’t need anything out of the ordinary.
to clarify, you're saying to soft solder ta plug of brass in, then drill and tap....not just fill the hole with solder.
For brass main plates with stripped holes, I usually try a screw which is around 0.1mm larger and try to self-tap with the new screw itself. Just add a little oil and screw/unscrew repeatedly while removing any swarf.
If you do buy a tap/die set, avoid the (possibly Indian) set in carbon steel which may be sold by Anchor as it’s awful (poorly made, not accurately cut and break easily). Get the HSS set which is possibly Chinese and made by Toolzone or similar for £30 - £40. It’s excellent.
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
