Mainspring for JLC
Your "watch-repairer" can't help you and lets his client to find out :huh: ??
You need to know what kind of tail end it has; automatic or none-automatic (NB, DB, DBH, T or TR)?
If you can't find the correct spring, you can use the reverse engineering estimate calculator in this website;
http://www.vintagewatchstraps.com/mainsprings.php#
then you go to CousinsUK and find the closest in thickness and length with the correct tail end and correct height.
https://www.cousinsuk.com/product/under-100mm-height
In your case, the height has to be 0.95mm (or slightly lower) otherwise you can't close the lid of the barrel. The length and thickness can vary a bit. Thinner is slightly weaker, thicker slightly stronger which could cause knocking or banking.
Perhaps it is also a good idea to introduce yourself first, so we get an idea who you are and what kind of watch skills you have .... ?
5 hours ago, Jtalleruphuus said:
Jaeger LeCoultre from 73
It would've been nice if the watchmaker had given you a model number? Then is this an automatic versus manual wind watch? The problem with finding specific parts is the part you're looking for may be the wrong part which is why you're not finding it. That's why it's better to start with the basics of the model number the watch we can look it up in our references and see if they all agree. Plus it's also helpful to measure the original spring to make sure that agrees with whatever you are finding in the specifications. Occasionally we get some strange watches were nothing agrees Which makes things much more interesting.
2 minutes ago, praezis said:
Watchmakers normally don't measure the old spring, as it might be already wrong, but determine the movement calibre and look up the correct spring in tables.
I like the word normally? This is watch repair there is no normal.
So normal I assume means modern then you're right. In modern watch repair you can look up the part all the parts and 99% of time they will fit perfectly. Typically modern watchmakers are attempting to restore the watch to new condition with their new parts they don't worry about what's in their.
But what about watchmakers like me? I primarily specialize in antique watches some of those don't have markings there is no caliber number I can't look up the mainspring. Or American pocket watches for instance there tends to be variations. So it's very helpful to start with what is in the watch. It doesn't mean that that's right but it gives you starting point. So I measure every single spring I take out. I verify that whenever I took out agrees with whatever the books think is supposed to be in there and if they don't then I need to find out why.
Hi,
first, my post was no reply to yours, just a few seconds later.
Is this an antique watch? .. from 73 did not sound so. For comparing it is not wrong to have the sizes of the existing spring, but I would not use them for finding the new one. If calibre and references are not  available, I use to take the sizes from the barrel and apply general rules to find width, legth and thickness of the spring.
Frank
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
    • Why just the bottom mike ? Is it worth polishing the whole arm ?
    • The one thing I took time over was to round and polish the curves at the bottom of the jumper arm. The slightest mark (left over from cutting of filing) acts as a stress raiser, just where you don't need it.
