Tag Heuer 1000 Quartz
arkobugg
Cheers Mates!
Im working on a Tag Heuer 1000, and when was done fixing the watch. It would not start again when putting in battery. Are there a reset thing with these movement. Somebody know??
It was going just fine before I took out the battery.
14 minutes ago, arkobugg said:
Cheers Mates!
I have to add to this case, that I had to go in an do an correction because this lever her was misplaced?? see photo: So I placed in the slot to the clutch wheel. I hope that was right??
Edited by arkobugg
That is correct. Hope that would solve the problem and that the movement will work again. They are not that common this days and aren't cheap to replace.
Edited by rogart63
24 minutes ago, Gpsluvr said:
Did you cover up the gold negative tab with the orange insulator by accident? It has to be showing with the little tab on the insulator under the metal terminal tab. Steve
Sent from my iPad using Tapatalk Pro
Pls explain more what you mean ? Do not  understand ....
In the area of the top right of the orange insulator where it has a tab going up into a channel, there is supposed to be a gold metal springy tab sticking out and above the insulator. That is what the battery makes contact with on the negative button. The insulator is there to prevent the battery from shorting out to the body which is positive when the battery is in. I can’t see the metal tab at all and assumed it was under the insulator, but I don’t really even see it there, looking through the insulator. It is possible it is completely broken off, which happens all too often if battery acid corroded it. Pull the insulator out and look for it underneath. It should be obvious if it is there. Steve
1 minute ago, ecodec said:
Gpsluvr points out that the small negative battery terminal appears to be underneath the orange coloured insulator !. The gold terminal should be visible on top of the insulator !.
Okay, than I will check that... thanks to all..
That is beacuse the minus tab is fastened on th print board that I have taken of the movment in the first movment. So the minus tab is laying nice an fine on this photo.
That lever is the yoke. It also has two additional legs: one inhibits the circuit when the crown is pulled out, and the other jams (hacks) the wheel in the centre.
Using a loupe, look into the movement and pull the stem in and out. You should see the hack lever touch one of the wheels, but only when the crown is out.
Also make sure that you did not scratch the coil when changing the battery. That’s a common fault.
13 hours ago, JohnR725 said:
did you ever get your watch running?
Nope, It started with that setting lever was stock in outer posision, so I had to go in via the calender work to get to keyless work, but when I was putting things togheter, I noticed that the clutch wheel could not move along the stem, somthing in brass was jamming the clutch wheel. So I had to take out the print board, and the I found out that the yoke not was in the grove in the clutch wheel. So I placed that right and put things togheter the same way. After that the watch would not start...But I have a friend that are an expert on quartz Tags, so he can fix this. Im more into mechanical watc myself...
one of the things really important when asking questions is to give a proper description of the problem?  In other words  I see that you took the battery out  you put the battery back in it was running before and now it's not running? But  you also indicated you are fixing a problem in the original question you didn't explain what you are doing?
Then your photograph and your better description of what you did.. The photograph  it appears to be a crown gasket has failed  and rust is migrated down the stem.. The one plate screw in the photograph has the same discoloration like the stem.. This indicates that moisture has  entered the movement. This very likely cause the original setting problem. Then no watch likes rust quartz watches are we way more sensitive. The gear train just has no power for anything that's  going to cause a friction and that includes rusty pivots and the oil going bad. then the photograph of the seconds stop lever the part that goes into the clutch wheel doesn't look quite right in the photograph? It might just be an optical illusion in the photograph.
So if you have a friend who is an expert on quartz watches it's time to visit your friend..  The other problem with quartz and electric watches are  you need test equipment to figure out what the circuitry is doing whether it's working or not  whether the current consumption is too high or whether the coil.is open because it got scratched or bumped.
Hello JohnR725
I appreciate very mutch all the good help I have got during this watch repair!   But that is why I usual stick to mechanical watches, and that this was just for a really good friend. And that I usually dont do quartz.     Thanks to ya all...    :-)
JohnR725
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
