Seiko 4006 - Bell Matic
Cmmb8519
Hi everyone
Just recently bought a 1969 Seiko 4006-6000 Bell-matic to start a new amateur restoration project.
The watch came from Peru and it was very bad serviced. The amount of oil inside is enough for myselft and wife to cook for a week [emoji846]
Fortunately, every thing seems to be working. Only issue I found so far is on a bearing of a plate that holds the alarm works, which is weared out (see photos) and the alarm hammer moves out place when actioned, resulting on a very low alarm sound.
The bearing hole is in a oval shape instead of round.
Any advise on how to replace this? Where to buy it? How to take accurate measurements to buy the right thing?
Many thanks all. 702bb3ae3daf433a6887fe2aab23a931.jpga1d51a63f24e3802c7ff7af26a153e9e.jpg
Sent from my SM-G950F using Tapatalk
Hi there,
Thin and easily breakable dial feet is what you should be very careful with, that is if it got on ship with feet to begin with.
I got spare parts, just how I can come to rescue you from fortune hunters is not as easy as sourcing from available providers.
As usual I suggest taking picture at each stage of disassembly. I have several in my collection all of which I have serviced myself, I'll be with you till last drop of blood.
Synchronizing the bell with the watch is a pain and often inaccurate.
Alarm set works is a usual problem.
Regards
Hi there,
Regards
Hi Nucejoe
Thanks for your comments and availability.
I have the watch now fully disassembled and was able to find the Seiko tech spec chart for the 4006 and a couple of videos that helped a lot.
Already ordered a new mainspring, new crystal and all gaskets from cousinsuk.
Only part I'm looking how to source is the metal bearing for the alarm works plate. See attached photo of the all plate.
Wonder if there is a way to buy this bearings from new stock (beleive there is but I'm not sure how to measure and search for it)? Or if is better to get a damaged movement and just move it across?
I would just get a used replacement barrel and train wheel bridge. That click spring also looks bent. I suppose you could press out that metal bush and replace it with a jewel. Its finding the right size that's the hard part.
Is the watch 27 jewels given the mainspring and alarm ms arbors have jewels?
Thanks very much.
Yes, it is the 27 jewels.
    • I have a barrel bridge arbor bearing that needs a slight reduction. I have never closed a barrel bridge arbor hole before and my staking set has a very limited number of doomed punches and most of them are too small (go through the hole) or too short to fit in the lower section of my inverto-style Boley & Leinen staking tool. So, I'm considering ordering a few doomed punches from CousinsUK. My question is what sizes I should order? Is there a rule of thumb relating to the hole diameter? I too worried that reducing the hole size would increase the end-shake. Especially as Kalle Slaap talks about end-shake at the end of the video at 7:43, but then he just glosses over it by saying "You can just gently push the material back in", which I don't get at all 🤔 Anyway, I feel a lot less worried now after having seen @mikepilk's excellent illustration. Thanks!
    • If you have access to a 3D printer, here is my design I did a few weeks ago:
    • I finished my polisher yesterday, and just tried it out. I'm surprised how easy it is to get a good result - just a couple of minutes. I thought it was going to be more difficult - a nice surprise as most things in watchmaking are harder than you expect. I bought self adhesive 3M lapping film https://www.cousinsuk.com/product/film-lapping-3m-261x266x , 9, 3 and 1 micron, and stuck it to sheets of glass. The 9 micron is course enough to remove large scratches.  I'm glad I used the M6 thumb screws as the large heads allow for small adjustments.
    • I used  green blotting paper under thick glass and a few tiny pin nails on the sides of the glass to stop it from moving. I also had wood beading all around my bench to stop things rolling off.
