Strange Timegrapher display
mikepilk
I just put a Revue MSR T43 on the Timegrapher and I'm getting this odd display.
Visually it looks to be in beat, and the amplitude looks good.
I don't understand how you can have two close traces and a large beat error. Don't they come from the same signals ?
I can now answer my own question - I should have done some more searching.
I found the thread   3407-single-line-and-57ms-beat-error/
It appears that with a Weishi 1000, with a beat error of about 5.5 ms, one plot rolls-over and plots close to the other, giving the false impression that they are close.
I followed the advice in the thread, and moved the stud arm clockwise - problem solved.
It goes to show that you can have a huge beat error, with relatively little effect on amplitude.
I had long educational lessons from @JohnR725 and he mentioned this "overlapping" problem when "way-out" of beat. My Laco's are statically in beat, but the software showed 9.8 ms ...... We are still not sure what's going on; software or mechanical....
I read the thread you are referring to and it's amazing to see how many times JohnR725 stepped in with his time-machine knowledge .....:thumbsu:
Anyway, you found the answer and solved the problem ;)
Edited by Endeavor
there are several important rules to remember when using the timing machine. First pay attention the numbers and the graphical display and make sure they agree plus visually look at the watch and make sure whatever the watch is doing agrees with what you see on the timing machine. Then my favorite phrase for timing machines is garbage in garbage out. If the graphical display looks like total crap the numbers will be the same. Is not like the timing machine can magically look at the random dots and produce a rate or an amplitude that is going to be correct.
I did a visual check that it was in beat, and the amplitude looked good, which is why I was confused with the display.
Another lesson learned.
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw Darwin’s theory of evolution has not been proven to be absolutely.  😀
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
    • Hi.  I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt,  long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved.  Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece  and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice.  We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it.   The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car.
    • I haven't gone through all the reading of what it might be or not. The first thing I would do if nothing obvious stands out is replace the mainspring, you have to start at the source of the power. Nine times out of ten that is the problem.
    • Haha. You're just in a wicked mood today John 😅
