Hello all!
Wildboar
Hello,
I’m a uk based watchmaker mainly working on early verge escapement pocket watches. Although they are, in principle, a lot less complicated than modern wrist watches there aren’t any spare parts available, so I end up having to make from scratch or adapt something.
I’m now starting to learn a bit more about wrist watch work, mainly vintage watches, so have joined here for some tips and information. At the moment I’m cleaning and repairing my own Universal Geneve polerouter date, with a lovely caliber 69 microtor movement.
Thanks for reading!
Hi wildboar, welcome and keep it up !. Nice hobby but can be a bit trying at times. I have almost given up on an old verge watch. Trouble is that I did not get there first.!! Regulator plate screws missing and balance seems a bit too worn. Cleaned it and assembled then chain came off so it is back in the junk box !. Maybe later, who knows !. Best regards, Mike.
I usually wind the chain on last. I wind it onto the fusee then hook it onto the barrel and slowly wind it off the fusee onto the barrel using a watch key on the square on the barrel arbour. Of course make sure that the verge and balance are out of the watch are out when you do this! It’s then just a case of getting everything set up and in beat....
Thanks wildboar. I have torn it down again, you gave me the inspiration.  I will "make" the missing screws and put it together after further inspection. I have put the escape in the correct position but now need to check the balance bearings, particularly the one that goes thru the escape into the bearing there.  My method of chain assy is to fix and wind the chain round the barrel first and then hook the other end in the fusee. Then wind a little tension to keep it there and stick a dressmaking pin thru the contrate "crown" wheel if you like to hold it there whilst installing the balance and paddles. Fit regulator, pin h/s and  install balance bearing plate and then remove the pin. I hope to have better luck next time. Thanks again for your comments. Regards, Mike Nr. Soton UK.
  • 2 months later...
G'day Mike,
It's been a while since you posted, but this is the way I was shown to stop a verge drivetrain.
Fold over the edge of a piece of paper and cut a dart out of it.
If the point of it is too long and fine I snip it off.
Then poke it through the contrate wheel. Can't cause any damage as it's structure is way softer than any of the components.
One of the old texts I have, as a PDF, by Berthoud, says to stop the train by means of a hair or piece of paper. I'm wondering if the hair he's referring to is pig's bristles? They were in use for all sorts of things back in the 1700's, and would be stiff enough to do it. I use them as needles on the threads I hand sew my shoes with, and they are very resilient things :)
Hope this was helpful.
Cheers
Duncan
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
