Unita 235 click spring?
Len33
I need a click spring for a Unitas 235 pocket watch.
Nobody (That I have tried) has been able to heip and, in order to make one, the spring has to be
about 0.1 mm thick and no more, because it passes under the winding wheel.
The click springs that I have are too short to re shape.
Any ideas where............?
Thanks.
Are you sure your dimension is correct?
I have a 235 apart at the moment and just measured the click spring and it was 0.21mm.
You can buy electric guitar strings down to 0.007 inches, but 0.008 inches should do you at 0.203mm
https://www.stringsdirect.co.uk/strings-c1/single-strings-c810/electric-guitar-c534/daddario-high-carbon-plain-steel-single-string-008-p6466
You can buy plain steel and high carbon steel, I'm guessing the high carbon steel ones would be better to make the spring from, but I stand to be corrected.
Thanksfor your suggestions.
I do have some of Cousins 'Shepherds hook' springs, but they are too short.
As obtaining a spring wire suitable for the watch is proving to be quite difficult, the guitar string idea seems to be the way to go with this.
Incidentally, at 0.1mm thick, maybe that is the reason for this click spring breaking in the first place.
Anyway, "thank you," both.
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
