Tool porn!
margolisd
For a newbie, what in the world is this used for?? :huh:
It's a tool kit used for fitting and removing bushes and jewels from watches or clocks. It has some other uses but that is the primary function.
The set above is a very nice example.
Sent from my SM-G950F using Tapatalk
Cool, i have seen these around ebay when scavenging around for vintage tools but had no clue it was even related to watchmaking. Makes more sense now.
Lovely set JD.  Is it all complete?
I think it is almost complete. I looked at the Seitz manual and compared it and found that some pieces were just in the wrong place, like those collets on the bottom left. There are only a few open holes. I really wanted the pivot straightening device as they are usually 300 bucks alone. I already have the lower seitz kit and a jeweled ruler and the plate holding device. So the plan is to put all the parts in the right place, determine the gaps and if I really need to fill them. And then sell the individual items I currently have. It should arrive Monday.
Sent from my GT-N5110 using Tapatalk
I managed to pick up pretty much all that you have there JD, only not as a dedicated set.  I really do like boxed sets of tools like that.
I have duplicates of almost all except the pivot straightening device which typically goes for around 300 on eBay and 450 new.
    • Snap! I recently finished my Gruen 510 movement - though the case for mine is in a rather sad state; I'm going to try re-plating it (in nickel, it's not a gold one).   Re. the screws, I got a few of the one gram mixed batches from ebay. I've only needed a couple of screws for things so far, both rare, minuscule types - but both in the mix, after enough time sorting through them! The ones such as normal bridge screws are quite common in those lots.
