Lubricants
Docbondo
Hi, I'm a total newbe but i am enjoying this a lot! I am starting my new hobby by working on Seiko 6309 divers.
My question is: Seiko calls for 4 kinds of lubricants. Moebius A, Moebius V, Seiko S-2, and Seiko S-6. What are the commonly used lubricants?
I have seen synt-a-lube and others in Marks videos. What should I be using as substitutes for the above?
Thank you for your help.
Mike (newbe)
Edited by Docbondo
Hell there...
I'm not the expert on this, but there are several threads on lubricants. I mention this as it is like discussing politics at a dinner party... It may not go over well.
But, I do believe you can refer to the Mobeius lubrication chart and be fine. Watch will require re-regulation but that's normal anyway.
Good luck!
Depends on what you're lubricating.  High grade watch movements are pretty specific and you can look them up by manufacturer.  But the same manufacturer (e.g. Rolex) may have changed their specifications several times.
For most of what I do--none of it really high grade as well as old pocket watches--I use Moebius 8000, HP 1300 and 8200.  Henry Fried says you can use Vaseline in place of 8200.  For old pocket watches they used to use, among other things, sperm whale oil!  (My former instructor who has everything of historical interest to the watchmaker had some!)
Edited by DouglasSkinner
I don't think a Seiko 6309-729 or 7049 case would qualify as a "High Grade Movement." But I have to say that I think they are the best to start working on. Their simplicity makes them easy to work on, and their accuracy can be pretty amazing. But you have to kiss a bunch of frogs to find the really great one. The Barrel arbor and the baseplate seem to really get worked over. So I have ended up with 4 or 5 movements to make one really good piece.
I want to start working on Eta movements soon.
Thanks for all the help. I look forward to signing up for the courses.
M
ETA’s are fairly easy, and parts are cheap too, so unless you get something really old they are great to play with.
But the easiest movement I’ve torn into is the Rolex 15xx movement. It’s sort of a kin to a farm tractor. Simple, and overbuilt. Low beat by today’s standards but quite accurate. Generally, if not broken, just clean and lube properly. I like them. My only 3135 experience is a replica movement so I reserve judgement on the real deal.
    • All Done, Here are the finished pictures: This one shows the generic "one-size-fits-all" base which accepts the bespoke rings - notice that the parametric movement OD (27.40 mm) automatically prints on the ring 🙂 From another angle: Here is the ring about to go into the base: And finally the base and ring together: Here it is next to a pen for scale: On my system with 20% fill each ring will take about 18 mins to print, but I am sure this could be optimised: Here is the screenshot of the spreadsheet in FreeCAD, you just need to change one value to create the ring in cell C3, (the base doesn't need any changes). I'll upload the files to printables in due course, but here whey are as a fake pdf, please change the .pdf to .zip to make the file worn once downloaded: Modular Movement Holder.pdf Any feedback welcome!
    • I'm going to give that a go next time, thanks for a great idea @rossjackson01 One of my students uses this tool and swears by it https://www.cousinsuk.com/product/wheel-hand-roller-remover-bergeon?code=W1851 which is very like getting two sticks of pegwood under the wheel and rolling them in your fingers so they create a slight prying from underneath motion, I suppose. Maybe bind one end of the two sticks of pegwood so they are like tweezers.
    • Thank you. I spent a lot of time on that.   It never ceases to amaze me that there are so many slight adjustments that can be made to the chronograph mechanism through setting the eccentric studs to get them all to a concerto, like an orchestra with everything in time and to its most optimum. Understanding that setting one stud to the desired effect may throw another out is the fun of working on vintage chronographs. Great pic of the 3133 dart tooth interaction and tilt of the tooth. I love working on 3133s. Slightly better than the 7733 in my opinion and you get a date at 6!
    • Thanks Richard The stem is 0.6mm wide. At least the part that the crown goes onto. Is that enough info to order a new stem and crown and look a pics of the stem so check that the part that goes into the keyless works matches the one I have? Asking out of ignorance! Cheers, Nick
    • Probably Chinese, you can measure the stem you have.
