Roller adjustment
margolisd
Hi folks. For watches where you can't set the watch in beat by adjusting the position of the hairspring stud, my understanding has been that you must reposition the collet. I always find this incredibly tricky and dangerous. Once or twice my screwdriver has lost traction on the collet and I've damaged the hairspring resulting in much swearing. I just stumbled across this tool. Doesn't it make much more sense to use one of these to adjust the roller? Am I missing something?
https://www.cousinsuk.com/product/roller-adjusting-tweezers
Turning the collar on the staff will move the jewel and the hairspring stud further or closer to each other, but turning the roller, will move the jewel but the relative distance between the jewel and the stud will remain the same. In effect, the only thing that is turning is the balance staff. That's what I can see is different between the two methods. So really, the only way to bring the watch into beat is by turning the collar on the staff. I could be wrong, I'm going out on a limb...:blink:
Edited by Jon
When you remove the roller for what ever reason you want to try and position it back in the same place, that is assuming someone else hasn't already been at the watch and replaced it incorrectly previously.
The reason being if you place it differently it could impact the poising of the balance staff.
On a 2 arm balance staff the impulse jewel is generally positioned 90 degrees away from the balance arm.
I would of thought you would use that tool if when placing the roller jewel on you needed to adjust it to get it back to the correct spot, not for getting the watch in beat as you should be able to do that with just adjusting the hairspring unless you placed the roller jewel back on in the wrong spot.
If you look at balance from a vintage watch you can usually spot tiny marks on the balance rim that a watchmaker did in the past to show where the impulse pin should go and the hairspring stud to put the watch in beat (and hopefully keep it in poise).
I have that tool and the first time I used it it slumped dipped and I broke the the tip-off the balance staff. Hence I have never used it since. When moving the collet I make a mark on the balance rim opposite the split in the collet with a very fine maker. I then insert the smallest screwdriver I have (0.50mm) into the spit and turn the balance a minute amount. When putting the watch back on the timing machine you should then see if the direction you have moved it is the direction required. Note the recommended tolerance of beat error should be +/- 0.4ms but achieving this can be challenging. If I get a watch into the 0. area  I settle for this.
Ah, thanks all. That's really interesting stuff. So the position of the roller relative to the wheel is actually important for poise.
Yes, I often see the lineup marks left by other repairers and I've made a few myself to make it easier.
I really like the idea of using a fine marker to record the position of the split. I will try that out. Thanks :)
Hi
This is the Bergeon 30017 version of the tool used for adjusting the collet, comes in different sizes. Obviously pricey for what is essentially a hollow tube to fit over the pivot with a slight nib for fitting in the split on the collet. I picked some up second hand, perhaps simple to make your own? I find it a lot easier and safer than using a screwdriver.
Stephen
https://www.hswalsh.com/product/bergeon-30017-ttp-tool-hairspring-collets-hc30017-ttp
The roller can be moved to make slight adjustments to the beat. There were fairly elaborate tools made for this (will post a pic when I'm back in the shop). If the staff moves in the balance when moving the roller then the staff was not rivetted properly.
Large adjustments must be made at the hs collet to keep the poise and balance position correct. Fine adjustment at the collet is usually easier as well unless the above special tool is on hand. The tweezers are just too awkward. A microscope helps, the angular movement can be really tiny.
The tweezers from the OP are handy for adjusting a roller position after a restaffing or for getting a roller off when other methods don't work.
The tool for turning the collet is good and works well and safely as long as the cock can be manipulated far enough out of the way, not always the case.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
