Making a Balance Staff
Need to make a balance staff for a European picket watch. The old staff had both pivots broken off. First I disassembled the watch and removed the balance staff. Removing the roller table was the hardest part because it was a Three arm balance and my Magic Roller Remover would not work so I used the scissor type.6747fe43a99bd188eacf952d9fef8dac.jpge7e75d9c69e9a769a9ad6711e9c6b4a6.jpg1fa88274beaa1d13932d30eec2514bed.jpgc078f7e520c6a346dfadcaff67cec649.jpg30f532e8ae4870da44c7cbcaa0281ed8.jpg1e2a163391ea846c35b2b298187f5b07.jpg844d0cfbd16fab2a941d595c66400080.jpg
I then determined the widest diameter of the balance staff and found a 2.0 mm piece of Blued Steel. I cut off 1 inch and sized the collet, and inserted in into my Boley Leinen Lathe. I then started to cut the Balance and Hairspring side by first using the old staff as a guide and marking the piece of steel with my carbide graver.84d1245e54d14e9c32e366e831d56e88.jpga8d59714009b2c8e9837c7d0a23a9576.jpg
I started cutting down the first diameter where the balance fits and simply cut and measure until it was snug but still room to stake it in place. I then cut the hairspring diameter next and fix and cut repeatedly until it was snug. I used a special gauge to measure as I went along. Once the part fit was good I worked on the pivot with the graver until I got it down to around 0.2 mm and then used a stone to get it to around 0.14. The rest I plan to do on a Jacot tool.0674a45da0908e5666cce3fe60dacaea.jpg5f5da6c0d5a8c8836f329b4007570fd4.jpg974ed69f2161befa35058fb02420bf8f.jpg
I then flipped the part around with a different collet and started working the Roller Table side using the same technique. I Amos finished off the plate where both the rolled table on one side and the balance on the other side rest.7f9288040022be85fb24dd8435190d3d.jpg
Slight error in the description. I left the full part in and started working on the roller table side before cutting off the part and flipping it around...saves time.fef5e1e9bedb5099cc57df61d48dd29c.jpge35b6f93179d1155af32162d51002e0d.jpg69dcc763d9f12d137ec285e3e6e5a2d8.jpg73865aa95c3ce5477a81ab5860cefa62.jpgae5f5dd2ca1ac1eaceaf541f66d0e1c0.jpg
I worked on the other pivot as well and got it down to 0.14 with a graver and then a stone...on the Lathe. The final product looked great. I am waiting for a set of vintage pin gauges to get the pivot size exact. Will finish it off next week.bae231293c9eefa9bb05910589d5ce6d.jpg13be0555c60fc6945650f2f963450b71.jpg
  • Like 8
More progress. As well, made a video on how to use Jewel Hole Gauges. So I staked the balance wheel onto the newly made balance staff, friction fit, and it fit really well. Very pleased . I then used the jewel hole gauges to determine the hole size and this the pivot size. Turned out to be 0.10. Now I need to burnish the pivots to that size, fit the part in the movement and once fit perfectly, I will add the rolled table and the hairspring.
Also lined up the impulse jewel to the center of two arms and then drew the line straight from the jewel to the pallet fork pivot then placed the hairspring on the balance loosely to align with stud; while the impulse was perfectly centred with between the banking pins.
    • I think it is friction fit, there are tools to remove them, cheaper versions are available. You could try adapting some pliers, see my crap drawing.  The pushers are available in various sizes, you could measure once the tube is removed.
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
