A. Schild 1746/47 assembly help
The spring is supposed to hold that small part/pivot next to it in tension which in turn will hold the calendar wheel in splace.
It'll prevent it from moving in the wrong direction but allow it to rotate in the right direction.
The movement that I had had a different spring than yours. It was shorter and it was flat not rounded.
Something like this.
Might be a good idea to check that the one that you have is the right one.
Edited by Chopin
10 hours ago, Watch13watch said:
If I put it the other way the long arm will go under the calender wheel so I dont think i can
I don't think you have the correct spring. The one Chopin has posted looks more like the part. But with out that plate it will not stay, it will become detached.
