HOW TO LENGTHEN HANDS OPENING
manodeoro
Hi,
I'm working on a watch project for which I need a really specific handset.
The hands I need really look like DJ hands but the opening (which will receive the lume) must be really longer.
I'm wondering how to do that and which toll I should use.
So if any member have already succesfully tried such a modification it would be really kind to give me some advices.
Thanks for reading
and here is a comparison pic (photoshopped) showing from where I go and where I want to go.
UPDATE ...
I had never searched OFREI website and it seems they have a handset that would fit my needs
It depends if the length they annouce are :
1 - measured from the center of the hole ... that would be almost perfect as I need an 8mm hour hand and a 12.7mm minute hand
2 - whole length ... and both would be too short
About the hole sizes I wonder if I can broach them a little.
The movement I want to use is a RAKETA 2609so hour hole size is 1.60mm and Mintue hole size is 1.00mm
So what do you think about broaching :
1 - Hour hand hole from 1.5mm to 1.6mm
2 - Minute hand hole from 0.9mm to 1.0mm
I think it's possible but I have never done that.
Hi Mattaphysics
Speaking about hand broachers I suppose you think about broaching the holes so taht they fit on the Raketa movement ?
My biggest problem is, if the hands sold by OFREI are too short, is to modify the openig on the hands.
Do you think I can do that with a square broach ?
you can find the square broach in the same section as the square hole drill which other than for woodworking doesn't actually exist.
the type of hand modification you're attempting to do is something not normally done in watch repair. Usually the only modification is to open the hole of the hand of a different size and occasionally trying to close the hole if the hand doesn't fit. I don't think I've ever seen any references to anyone physically trying to change the inside opening of a hand.
to understand the difficulties of modifying hands I found some videos on making hands.
https://www.kddl.com/watch-hands/
https://www.youtube.com/watch?v=U005_iEAa_A
so when you look at the videos you notice that anything involving a hole of any shape or size is done with metal stamping. Drilling holes grinding cutting with normal conventional tools is really difficult when the material is as thin as this.
The best option would be to Google watch and manufacturing and maybe somebody already has the hand you need. otherwise when you looking at the watch hand manufacturing companies see if they'll do a custom hand probably the want to do 100 though you can sell them on eBay recover your cost of having the made.
then not exactly a DIY project but cutting square holes in really thin materials EDM machine would do that and  a fiber laser should both work but gaining access to those is going to be a challenge they're not normally found in the local hobby shop at least not yet anytime soon probably.
I was closing my Google search when I noticed the website below. they have pictures and they're not just modifying hands they are actually cutting the hands with a laser.. Unfortunately they don't have any pictures of the laser cutting and process they do mention a company name accept the company makes lots of different lasers all of which look very expensive. But still does show what a laser can do for you.
https://www.ickler.de/en/steel-hands/
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
