citizen Pro Diver Watch
I have a citizen pro diver watch eco drive.  This watch has been tucked away for several years which was a present from my wife.. Low and and be hold the watch does not:beer_hat: work of course.... SO i DECIDED TO CHANGE THE BATTERY, after changing the battery the watch doesn't work. I do not know what the problem is . Help?
Pictures? More information? Did you buy the proper rechargeable battery for it? Did it mount the same way, with a little tab sticking out of it? The tab has to make proper contact with the one on the watch itself. Then if the battery didn’t arrive charged up, you have to set the watch out in the sun for a few hours to charge it. (A very few models have a battery that looks like a regular one without the tag but the rest still applies. What is the model number of the watch? Steve
Sent from my iPad using Tapatalk Pro
27 minutes ago, honeybee50 said:
The model number is B873M, the battery capacitor is 295 5600, which goes with the model number for this watch. On the battery case is MT 920, this is the same style battery that I use in my Skyhawk........it works in the Skyhawk, but not in the Pro diver?
    • Haha. You're just in a wicked mood today John 😅
    • Heres my watch of today, a Smith 13'" RY . My missus bought me this for this Valentines day a bargain 14.99 with a reduction, the seller has occasional 20% off offers now and then so it was about 15ish with delivery. I love Smiths and i love bulleye dials, this is my first one. The watch arrived non working as stated and i knew what was inside and what would be against me, but i enjoy a challenge, we dont expect a lot if anything from pin pallet movements. A balance pivot was broken and i didnt have another staff but i did have another RY with a battered dial so i robbed the balance and tweaked it around to make it work apart from that mostly just a good clean and relubrication. Keyless works are pretty rough by design and the crown is a bugger to get in and out with the dial on, the setting lever hits the dial before it releases it, so a little mod is needed to help that along. Major problem was the pins on the lever were quite worn which make the old tg have a snow storm fit. Its a similar read for most pin pallets, these were brass as was the escape wheel. But perseverance is me, i didn't change the pins but i did spend some time dressing and polishing the worn areas which improved the trace a lot with some straightish lines 😅 and a beat error of .5 . Not sure what the lift angle should be on these and i Wasn't in the mood to work it out and who believes timegraphers anyway, but at the default 52° it runs with 260ish full 210 after 24 hours dial down , the verticals rates were pretty much all over place. So lets just put it in it's superlight aluminium case and see what happens. Been wearing it now for 3 weeks and it's consistently losing around 1.5  minutes a week winding each morning i think pretty good for an old pin pallet watch. I just love this dial, thanks wifey heres my Valentine's gift for yer sweetie x
    • I have a PDF below that will help. The problem was the PDF wasn't designed for this purpose it was designed to tell you what size watch you  have. Then it doesn't take into account movements come conceivably in different thicknesses.   watch-ligne-size-chart.pdf
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
