Getting the back off...HELP
Luke
It either screws off or pops off. Do you have a watch back wrench? They have three adjustable points that would go in three of those holes at 120 degrees apart and you would the just turn the wrench counter clockwise to unscrew it. Failing that, if it has a small lip around the very edge of the back somewhere, then you would use a blade designed for the purpose to pop it open like opening an oyster. Don’t try using a pair of needle nose pliers to unscrew it. Too many backs are covered with bad scars from trying that shortcut because they didn’t have the right tools. Steve
Sent from my iPad using Tapatalk Pro
