Watch Marker Fell Off
Zippy
Introducing yourself would be nice first.
However this is a very simple fix providing you have the correct equipment. The rear case back will have to be opened and the watch movement removed. This will require you removing the watch stem. Once  the movement is out of the watchcase just glue the marker back on then the reverse procedure to re-assemble.
Don’t forget to take the dial off and glue from the back of the dial. That way the glue won’t show and you can remove the old glue from the rest and Re glue them all like new. Little harder, but the right way.
