Watch Marker Fell Off
Zippy
Introducing yourself would be nice first.
However this is a very simple fix providing you have the correct equipment. The rear case back will have to be opened and the watch movement removed. This will require you removing the watch stem. Once  the movement is out of the watchcase just glue the marker back on then the reverse procedure to re-assemble.
Don’t forget to take the dial off and glue from the back of the dial. That way the glue won’t show and you can remove the old glue from the rest and Re glue them all like new. Little harder, but the right way.
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
