Timex manufactured in Great Britain
My wife has an old Timex watch that was her grandfathers. When I took it apart I could see inside the case cover it was stamped Great Britain Timex, but it also has the three letters KFW stamped in blue. Also would like to know what year this watch was manufactured and what movement it has in it. Thank you very much. Hope the pictures are clear enough.
Forgot to add that on the dial it has the following numbers: 1605002414, tried looking it up in GOOGLE, but nothing. Thank you again.
Edited by 2lostsouls
Had to add the serial number to my post
1 hour ago, 2lostsouls said:
Thank you. Is there a way I can tell when it was manufactured and what movement it has? Thank you
Yes the small reference number at the bottom of the dial tells me your watch was produced in 1974 (its a 7 not a 1 )and has a calibre M24 movement fitted
you have a 1974 Timex "Mercury" with a number 24 movement.  I can see the dial is in poor condition, the seconds and is missing and the top left lug is bent.  Timex produced parts and made final assembly across its many world wide locations.   In general, case will have Great Britain stamped in them and you may see Germany as well.  Dials may have Great Britain, France, Portugal, West Germany.
Movements made in Dundee would say "Scotland".  You may also see "Mexico" or Philippines.  The ink stamp many times indicates where and when made.  But sometimes it is just the where.  Sadly, I have yet to come across any relied method on how to decipher "the where".
Is the watch running?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • Yeah, I saw that in the tech sheet but I don't see how it can be adequately cleaned with the friction pinion still in place. I've accidentally pulled the arbor right out of the wheel once when I used a presto tool to try and remove it. Mark shows how he does it with the Platax tool. Those are a little too pricey for me so I got one of these from Aliexpress and I just push down on the arbor with the end of my brass tweezers. That usually gets it most of the way out and then I just grab the wheel with one hand the and the friction pinion with the other and gently rotate them until it pops off. Probably not the best way but it's seemed to work for me so far.
    • Thanks, Jon Sounds like a plan. Obviously I'll have the face on so do you think gripping with the holder will create any problems, but I will check in the morning to see how feasible it is but I assume it only needs to be lightly held. As for holding the movement instead of the holder won't be possible in this scenario as one hand will be puling on the stem while the other pushes the spring down. That was my initial concern is how the hell can I do this with only one pair of hands. All the other times I've had to remove the stem hasn't been a problem, apart from the force required to release the stem from the setting lever, but now I need to fit the face and hands its sent me into panic mode. If it had the screw type release things would be a lot simpler but that's life 😀   Another thing I will need to consider is once the dial and hands are fitted and the movement is sitting in the case I will need to turn it over to put the case screws in. I saw a vid on Wristwatch revival where he lightly fitted the crystal and bezel so he could turn it over, is this the only option or is there another method?
    • Hi Jon, do You think that relation spring torque - amplitude is linear? I would rather guess that the amplitude should be proportional to the square of the torque. I had once idea to check it, but still haven't.
