Repair help on MB Nicholas Rieussec
leebo
Hi all, I am a newbie here. Currently I am having problems repairing my MB Nicholas Rieussec watch. As this had a Minerva movement and had little experience. I am facing problems on removing the chrono disc. Conventional Chronos uses needle, however this model uses a disc to register the timed lapsed. Does anyone have any experience or advise on the disc removal and installation. Thank you in advance to your kind input.
Kind regards.
Leecbo.
Hi Leecbo,
It's unlikely anyone has had one of these across the bench, I imagine they go back to the manufacturer in general if in need of service. I would say that if one is comfortable enough with repair work to dive into an automatic chronograph of unique design it'll be pretty evident how they are attached once in there. My guess is they are pressed on to pivots, and the safest way to remove them would be to slide some watch paper under them and then lift off the dial, pulling the discs with it.
How far into it are you? Can you provide some pics?
Hi Nickelsilver.
Appreciate everyone's kind input, in fact the watch is with my watch maker now. You did mention, This movement is of an unique and modern design and most watch smith will not have much or any prior experience on the removal/installation of the timed lapsed counter/disc. however I feel its a good try to explore the repair on this design.
From the attached photo and looking at the disc, I do agree with you those are press fit and I believe proper removal will need a designated puller with the claw place into both the hole of the disc, claw on the underside inwards towards the center and acting the fulcrum force on the pivot pin to exert to upward force to extract it.
Am I in the right approach? Any further input are most welcome. Thanks in advance.
Kind regards.
Leecbo
Hi Nickelsilver and all..
Thank you for your valuable insight and the photo of the puller. I will look into the extraction and update of any progress.
Any other further help or suggestion to this issue, as other method or tools applicable/ available are greatly appreciated.
Many thanks for all your great contributions.
Kind regards.
Leecbo.
Also consider using something simple like the Bergeon 6938. These are very inexpensive little pieces of durable plastic designed to protect a dial when removing hands. However they might also be ideal for sliding under your discs thereby exerting an even pressure on the underside of each disc for removal with some simple leverage.
Whilst it's not your exact model of Nicolas Rieussec you might be interested in this video...https://www.youtube.com/watch?v=ZshUb8HEZ_8  ... especially about 30 seconds in!
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
