Timex Model 276702572 - Before and After
JerseyMo
Just finished up this repair, a classic 1972 model in need of much TLC.
Here is the before  and After, followed by how I got there.
and this is how I got there -  pop the case off and unscrew the set lever screw about 2.5 turns.
out comes the movement and the tear down begins. While doing so I see the crystal will have to be replaced as well as the crown\stem.
I also spot an oil spill on the date ring, this means someone has been in here before and did not know what they were doing.
So off we go for the cleaning and rebuild.  Finished watch looks and runs great.
Cleaned, oiled, missing and or worn parts replaced.
How does it look?
and here it is ready to wear.
You really did an awesome job.
I wonder if the bezel was missing a first and if yes where you sourced it.
Having some Kelton watches (Timex's French sisterwatches) I have repaired some of those bezels but when they're lost it's difficult to find one.
Envoyé de mon Moto G (5) Plus en utilisant Tapatalk
Yes, finding NOS Timex bezels is not easy and I have only come across them a few times.  the last coming from a large lot of parts from a New England supply house that had closed down.  It took me 3 months to organize and box up the inventory of hundreds of parts envelopes.
This bezel ring came from another watch and had a crack just to the left of 12.  I was able to use some super glue to get it to hold together.
Now you say that ... I can see the superglue near the 12th.
I have found a way to repair those plastic bezel "from the down side" so that they can snap on the watch rehaut and still be rotatable (seems important to me though that's useless cause those watches are NOT divers).
I have already posted my my method on a French watch forum but I'll write tutorial in English and post it here as soon as I can.
So if you ever fell on one of those bezels broken on 2, 3 or even 4 parts please ring me cause I need 2 of those bezels to finish my last Kelton's.
The bezel does rotate very easily and I have now cleaned up the glue on the front.    Yes, please present your method pn how to repair the bezels.  It would be interesting to see how others go about such a task.
Edited by JerseyMo
added information
Hi JerseyMo ... I have posted my repair method here
English is not my native language so fell free to check and help me to edit that tuto
    • @JohnR725 that's very helpful.  I appreciate the time you took to give those instructions and post the pictures.  below is a picture of my staff, which looks identical to the ones you posted.  The approx measurements I got are: .772 on the left part of the staff; .715 on the right side of the hub; the hub is 1.107; and the overall length (minus the broken pivot) is 5.248; which seem to line up with the measurements you posted.  I didn't think to measure the pivot, which I'll do if there's enough of one left on the staff.  Thanks again.
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
    • I think it's stamped on the inside cover. 309 I think.
    • Hi all, needing a little help. I have an old Casio AQ-321G, but have no idea what battery it takes. I've looked around online, but cannot see anything... I see a 309 stamped on the case back, could this be it....? Can you please help, below are some pictures:
    • The radial teeth are for hte seconds register, and the other (which is simple and doesn' take away significant torque from the train) for the minutes register.
