1920s Waltham w/ broken stem split collet
Hi experts,
I have a Waltham wristwatch from the 1920s. The movement is a 1907 grade 361, and it's basically functionally OK except for the stem. The little split collet that goes into the case and is supposed to keep the stem in place is broken, so my stem keeps popping out into the set position, or just popping out of the movement and case if I try to wind it. Does anybody know anything at all about sourcing a replacement collet, about putting together some kind of a workaround that allows the watch to function, or maybe anything about fabricating a functional replacement? Thanks a LOT in advance...
Are you basically talking about the rounded tip/end of the stem ?
Not sure how much luck you'll have finding a replacement but you can get a stem made by someone on a lathe or, hypothetically have the tip laser welded to the stem but I imagine that that might be complicated because the parts are very small but it's doable.
Have you tried eBay and the various watch part online shops ?
I'll post a photo tomorrow (night time here!) when I have time to take it apart, but I'm *pretty* sure that we're talking about different parts here. This is not a part of the stem, it's just a little piece of metal that goes around the stem and holds it in place so it doesn't pop out of the case. It's literally in the case, not in the movement.
I'm new to watches, but this is a system for holding the stem in place that I haven't seen on any of the few modern watches I've poked around inside.
I've looked on ebay, but unless I'm searching with the wrong term, all I can find are junk watches that *might* if I'm lucky have the replacement piece.
the little split collet is what allows the stem (on a stem set p0cket watch) to snap in and out.    I don't know of any one making them on  a lathe. it would need to be tempered and designed to work with the stem shape.  I have been lucky enough to find the pair on parts watches.   good luck, let us know how the problem was solved.      vin
I've never seen a press fit one either.
Apparently some of the smaller sleeves are hard to find now, I made a small one for a friend in the U.S. a couple of years ago and it was a pain to get it right. Way easier to make a normal winding stem.
But there are stocks of these things out there, do some digging.
18 hours ago, oldhippy said:
I think this is the part he is talking about. Its the stem adjuster that screws in side the case that the stem fits into.
  yes,  a collet and a depth "adjuster".    it must be spring steel or the collet fingers will break off.    I put an "o-ring" on top of this in an effort to keep water out.  vin
  • Similar Content
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
