cylinder escapement hairspring fitting
I am currently working on a small pocket watch which has a cylinder escapement.  Dis-assembled and all looks ok.  To get at the balance jewels safely, I decided to remove the hairspring from the balance (forgot to make refitting marks/refs of course!!).  I have seen Marks video on how to position a hairspring to be in beat when refitted to the balance of a lever escapement.  Is there a similar method for aligning the slot in the balance staff for a cylinder escapement?  I have seen literature of how to set in beat, would this be practical for refitting hairspring?  Any advice would be most appreciated.
Edited by canthus
The beat is adjusted by adjusting the drop of the escape wheel against the side of the cylinder. this should be about 3 - 5 degs. take the spring barrel out, and move the wheels with your finger back and forth till you can get it about the same each way.it may have three dots on the underside of the balance, and one on the lower plate. these show the 5 degrees each side of centre, but as for setting up the watch, this cant really be relied apon, especially if it has had a new staff fitted. will show how far it needs to move anyway. you adjust it by REMOVING THE BALANCE and altering the hairspring collet the direction you think, untill the watch is self starting, or untill you cant stop it in any place.
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
