Longines
speedy88
Hello!
I wonder if anyone can help me with my project! I´ve got a Longines "Comet", Ref. 8475, here, I guess you know this watch? Please view picture!
This is a new old stock watch! The problem is, somebody missused it! The hour "hand" is running to one ó clock, then stops....! The problem is, one tooth underneth this hour disk ist broken off/damaged! This thing is made of plastic, there is no chance to repair! If it was brass or other metal, there would be no major problem to fix it! Now i am looking for this hour disk or a set of hour and minute disk! It has been made in different colours, yellow, green, blue, red..... But I would take any colour! Even mix it! :-)
Would you please check your store for this? Maybe you know somebody, who can have this....!
Thanks for your help!
Have a great day!
Peter
Anything can be repaired. If the tooth is small (I know, they're very small) a new one could be made and glued to the wheel ?
Perhaps a 3D printer would help ? One that can work with really small parts. One with a high resolution basically.
What does it look like on the other side ? At first flance it can be made on a 3D printer provided that you make a 3D model of it (or scan it with a laser scanner).
You could also try and find a gear with teeth that are the same diameter and size. Cut those off and attach them to this one.
You could smooth out the surface where the tooth was broken and then when you get a gear with the same teeth you "extract" one of the teeth and glue it. (with a glue that does not melt plastic)
This is what I would do, probably but I can be a little unorthodox so don't take my word for it, necessarily. :)
Other options are finding a donor movement or maybe even this specific part.
A 3D printer would not be able to print a wheel of that size, the resolution is not good enough, maybe a high end commercial one could, but what you would pay to get it printed you could probably buy a whole new watch.
Dovetailing in a new tooth might be a possibility, but I think trying to find a donar watch might be a better option, although I'm guessing its not a very common watch.
Maybe find a wheel that has the same pitch and number of teeth. Have repaired a few seiko 6139 inner bezels with superglue but not sure that it would work on this kind of wheel? Very cool watch so it would be nice  if it could be repaired:
1 hour ago, speedy88 said:
Thanks everybody! :biggrin:
What about using the gear from a normal hour wheel of the same caliber? I guess, this has been made for regular hands!?
Does anybody know?
Peter
That was about was i was thinking. Remove the old and make the hole bigger. Maybe screws to hold in place.
I woke up this morning with an idea in my head for this...
1. Use a small amount of RTV silicone moulding rubber to create a mould from a good part of the wheel.
2. Drill a small hole a short way radially inwards from the damaged teeth, then join it to the damaged area with a slot that is smaller than the hole
3. Clean all the joining surfaces with IPA
4. Fit the mould around the damaged area and fill with epoxy resin.  Warm the resin slighty with a hairdryer to help it flow.  The hole drilled above will allow you to create a piece that will stay in place even if the bond between the epoxy and plastic isn’t brilliant.
Might be worth a practice with an old brass wheel first
5 hours ago, speedy88 said:
could anybody do that for me? I have not much experience with working on lathe and mill.....
But I can try to find a gear, maybe a hour wheel with the right number of teeth, diameter and pitch!
I guess, it will not cost a fortune, right? :-)
Best,
Peter
Hmm, let's imagine that you found an hour wheel with the same number of teeth and it's the same diameter or slightly larger.
Chucking that disc will be tricky, it can't be deformed and won't fit in regular stepped chucks or a bezel chuck (the hand protrusion would be a hinderance). Easiest then would be to make a friction chuck out of plastic like PVC, where the part can sort of snap in. This is done (by me at least) often to hold acrylic crystals that need to be modified on their diameter or internally to accept an original tension ring. The teeth would be turned off, and a little more.
Then the hour wheel would probably need a trip to the rounding up tool to bring it to size, as finding exactly the right size is less likely than finding one slightly larger, and it would preferably be tested on the watch itself requiring a bushing be made to fit it over the little hour wheel already in the watch. It would then need to be bored to be a light friction fit on the part and possibly reduced in thickness, then carefully pressed on.
The above would probably be 2ish hours for someone equipped and proficient and motivated.
If no wheel was found one would need to be cut. For someone with a good stock of cutters on hand and machinery ready to go for cutting, chopping out a toothed ring would probably be another couple of hours start to finish. One nice thing about hour wheels is they are so forgiving that they can be divided with a simple slitting saw of the right thickness and finished in the rounding up tool.
Figure 2-5 hours then. In my experience the better the watchmaker the more often he's gotten burned on jobs that should have been smooth sailing, and the more likely they'll quote toward the high side- and also the more likely they'll do the job right. Most watchmakers I know quote around 100 bucks an hour (close enough the same to be in USD, CHF, or EUR).
I don't know any, but am absolutely sure there are guys in Germany who can do this job. Is there any sort of watchmaker referral service there, like the AWCI in the U.S. ?
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
