Quick crown screw question
Gary
Hi Everyone!
I have a question about a crown screw. I have never worked on a movement with a crown screw like the one in the photo. Is this going to require a special tool? Since I don't have the movement in hand it makes it difficult to tell but I thought someone could share their insight, please ?
Thanks in advance !
Screw heads have broken of. jnash is right with tweezers but use an old pair, not sure about pegwood as it breaks, You might try a small screwdriver, but blade will get damaged. Anything in your workshop that can be uses to uncrew the little blighters that you can use. Depending how tight they are. A little oil might help. If you can take that bridge off and have a look from the other side that might help.
There are crown wheel screws that act as the hub which have two holes and can be unscrewed with some stubby tweezers (brass or nickel are good) or carefully with round nosed pliers. 99.9% of the time left hand thread. There were specific tools back in the day too, similar to ones used to disassemble the two piece barrel arbors on floating barrels.
But on yours it looks to me like the center part is positioned by two pins and held with one screw. It may be broken but might also may be screwed from the underside.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
