Timex V-Conic won't wind
Good morning everyone,
I don't know if this is the correct section for this but here goes...  I have inherited my grandads old Timex watch and would like to see it working.  He passed away in 1995 and I doubt it has been wound since.  The winder won't turn in one direction but it will pull out in order to change the date/time however, won't seem to wind the mechanism to run the watch.  Is there anything I can do/anywhere I can take it to be repaired as our local jeweller in Newbury (West Berkshire, UK) simply dismissed it and said it was scrap which I refuse to believe.  I have attached some photographs of the front and interior casing.  Any other information on this watch (ie: model, age, etc) would be very much appreciated!
Thanks in advance!
Chris (An old watch newbie.. and come to think of it, a watch forum newbie!)
1 hour ago, CPL4 said:
Do you have any idea what may be causing this?  Are these watches usually reliable or is this a common fault?
Thanks
   I find it common on any spring powered clock or watch as found to be "up tight".  you can feel "the click or pawl" engaging.  then you should find the pawl and  let the main spring down,  there is another  for that.  vin
Do you know of anywhere in the U.K. that would be able to fix this for me?  I’m quite practical with most things but I’ve never attempted a watch repair before so probably best that I seek some professional help with something that has sentimental value
2 hours ago, clockboy said:
If the winder does not turn it might be that it is fully wound and something else is amiss stopping it for running.
Do you have any idea what may be causing this?  Are these watches usually reliable or is this a common fault?  do you know of anyone in the U.K. that would be able to fix this issue for me?
Most you need to do is to follow instructions, especially on safe removal of the dial for it is suppose to keep the lookin and keep on tickin and possibly get another " scrap" movement for parts should it be needed.
Start taking picture as you get to date mechanism, facts are most highly skilled master watch repairers may not remember which part goes where. At this point you get bunch of guess ,however, get to fixing when you show pictures.
Welcome CPL4, I found this info regarding your watch. I don't know of anyone who repairs Timex. There are some on here that do, so you should have some help with it. The reason the watch repairer turned his nose up, is that they are hard to service and he didn't want to do it, as they can be really frustrating to work with. I had the same thing happen to me years ago, but I managed to breathe life into it by just a bit of oil in the right places, just to see if it would go. I'll have a go at stripping it one day when I'm feeling brave. It's a beautiful looking watch you have there, by the way
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?13&ranfft&0&2usau&1254322818
Looks like a 1968 Mercury with date.  Here is a quick trick that might get it to run.  place a few drops of lighter fluid on the backside of the movement.  This should be done right above the pallet fork.  See those two wholes at about 8 o'clock?  that is where the pallet fork is.
pour a little fluid in a plastic cup, than dip a pair of tweezers into the fluid.  next place the tweezers over the two wholes. Give the balance wheel a flick or two and see if it begins to swing.
if this works it just shows the lube has all dried up and causing to much resistance to the train.  It is just a trick and you will still need to lube the pivots and so on.
Now if you are looking for someone to service it I suggest Greg Ward in Lincolnshire  tell him Jersey Mo say hello!
http://www.woodlandtechnical.co.uk/ .
I’ve worked in a few old timex movements, it was one of the first movements I stripped and cleaned etc, they are sods as they are full plate movements but you get satisfaction out of getting it running. Anyway back in the day they were designed to be dunked in cleaning fluid let to dry and oiled and away they went, they weee also a throw away movement .
As has been said I believe the watch is fully wound and it’s just gummed up with old oil, the lighter fluid would work but there are still “holes” under the dial that would need cleaning and piping, which would mean stripping the date mechanism.
It really just needs a service and it’s a shame the watchsmith in your local town turned his nose up at doing the job. Keep us informed of how it goes, especially if you want to try it yourself we are here to help
  • 9 months later...
Hi Aleks   as promised these are the manuals The  phrase V-Conic refers to the balance pivot bearings which at the time were quite a different approach from the normal pivots. Withe the attached manuals you will be able to rebuild the watch no problem.  assemble everything on to the front plate and then fit the top plate , fit the balance last, is will be a bit of a fiddle.   Make some probes / tools from darning needles inserted into dowels. If you use cheap needles they will be soft and you can bend the tips might be of some use during assembly placing the gears.
21-22-23-26-29 timex.pdf timex 1961 service manual.pdf
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
