Which silicone gasket grease?
PeterS
Is there much difference between silicone gasket greases? I see that they are generally sold in sponge applicators but I’m not sure which grease to pick, too many choose from, Moebius 8513, Molykote 111, Seiko TSF-451, Silicon 7… just to name a few.
Any recommendations?
43 minutes ago, noirrac1j said:
I use KT-22 and it works well. It is designed as micro lubricant for winding gear, but also serves as a moisture sealer for gaskets.
J
Thanks, I’m guessing they are all good, kind of ‘take your pick’
36 minutes ago, mlfloyd1 said:
I would think that the sponge style would eventually dry out which is why I look for a jar or tube.
It doesn’t take much and it lasts a long time.
I like the idea, screw on lid to keep it sealed, put the gasket in, twist the lid few times and it’s greased. For my occasional use it’s probably more than I need. I guess I could load it with more grease when it dries/runs out.
KT22 is not good for greasing up rubber. Us e Fomblin silicon grese insted. Or Use Seiko which i prefer myself.
KT22 is for keyless work and stem. Some use it for the rotor but haven't tested that . Think it will get dirty fast.
Oh I didn't know that. I've used bergeon kt22 it on my gaskets with no detriment (as of yet), and although it is a heavy grease,  I don't use it on rotors. Maybe I should try the fomblin grease....
J
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
