rolex 1225
Its to help with fine adjustment of the regulator its not actually connected to anything you line the slot up with a gap in the teeth on the regulator then use a screwdriver blade to turn the regulator it stops the balance cock getting marked when adjusting and keeps the blade in the slot so it cant slip.
6 minutes ago, Jorgen said:
My Rolex has stopped. Can someone help me? What do I do? It's this Rolex watch:
First you tap it with a hammer, if that doesn't help you introduce yourself to the forum. Perhaps then somebody may suggest a new battery?
