Help finding a replacement movement for a Lorus novelty watch
jimfan
Hello everyone. Sorry if this is a waste of your skill, but if you could please help me I would greatly appreciate it.
I bought a fun Lorus Kermit The Frog watch. Its a Lorus from 1994. I took it to get a new strap and battery (I had some in the mail but I thought what the hell, support local), and the jeweler informed me that it wouldnt run. The battery leaked inside. He cleaned what he could, and seemed bummed he couldnt get it going. Though he mentioned the movement is replaceable which I didnt know.
Here's the tricky part. It says on the back of the watch and the movement itself that it is a V531-7A00. After a bunch of searching I understand that Hattori makes the replacements for these things. However, I CANNOT find a replacement V531. I've found V532, but not V531.
Before anyone suggests repairs or maintenance, I'll let you know that ship has sailed. After the jeweler declared it dead, I took it as an opportunity to try to fix it myself (having an interest in watches and a love of tinkering), and its assuredly more dead than ever before.
Does anyone know a good place to search for this movement? Or do you know if there is another movement that will work in this watch as well?
Thanks very much.
Sorry I couldnt figure out how to edit my original post with additional information.
What I'm finding out really strange about this whole thing is how difficult it is to find any information about this movement. For instance, on the Lorus website, they dont even list it on this battery chart. http://www.loruswatches.com/Battery
In my head there's two possibilties. One of which is that they only produced it for a very limited time and dont even have any documentation on it. The second is that it was just completely replaced by another movement. I think you can guess which one I'm hoping for.
3 hours ago, StuartBaker104 said:
According to this http://www.labanda.com.au/catalogues/labanda-mc-web.pdf, the V531 movement was also sold under the name VP31 (probably for Pulsar). There is one of those on eBay in Spain, or also here http://www.smithsupplyhouse.com/vp31.html
Thank you so much! Hahaha, boy have I been inside a hell of a google rabbit-hole. So I took a closer look at the pictures in the link, and also the ebay listings. Every one of the pictures is stamped with "Shiojiri VP31A". Now on this website http://www.boley.de/en/caliber/watchmovements/shiojiri/12351 it mentions "Hattory-Pulsar Y121 A". Could that mean that model is also an equivalent? I'm trying my hardest to source the movement in Canada to avoid getting annihilated on shipping costs. And maybe somewhere down the line a person with a goofy broken watch will thank me for all of this hahahaha
Not sure why Y121 is shown there - its a completely different size and shape.
With your new constraints, the best I think you’ll do is this https://www.somalcanada.com/product/1515~yr67-yr67.html
YR67 is the crrent equivalent Seiko movement. It is only 3.05mm thick instead of 3.3, so you may have to pack it a little, but the diameter is the same and so are the hand sizes. I can’t tell if the dial feet will line up, but you will be able to tell from pictures on line. The stem size is tap 10.
This will cost you very little to try and then you could resort to the ebay option if necessary.
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
    • I think it's stamped on the inside cover. 309 I think.
    • Hi all, needing a little help. I have an old Casio AQ-321G, but have no idea what battery it takes. I've looked around online, but cannot see anything... I see a 309 stamped on the case back, could this be it....? Can you please help, below are some pictures:
    • The radial teeth are for hte seconds register, and the other (which is simple and doesn' take away significant torque from the train) for the minutes register.
    • The original 6139A manual is very clear in how to disassemble and how to assemble ...... step-by-step. However I haven't seen the 3169B manual, even in the Japanese version around, which clearly highlights the difference in center-wheel.   6139A Seiko Technical Guide.pdf 6139_A.pdf 6139A.pdf 6139b.pdf 6139B repair guide jp.pdf
