New work bench
RickTick
Hi Guys
The underside of the bench is 870mm from the floor. This was a convenient height because I could then use kitchen breakfast bar legs.
I'm buying a new chair with adjustable height too as I sometimes feel I need to sit lower still.
Rick
I use a stool, I found a local company that makes commercial furniture and bought myself a dentist stool, it has a ring around the underside of the seat for raising or lowering so you don't need to hunt for a leaver when you want to raise or lower the chair.
It cost more than a stool would of cost at the local furniture shop, but it is better in every way.
I like your bench too
Dentist stool is a good idea.
As im a drummer, you may want to look into a drum throne as well. Some have back rests as well but the basic ones have lots of adjustments for height (usually threaded rod) and are quite cheap these days.
Hi Guys. Just a little updated photo of my new work station. Camera setup is great for helping me see what I am doing on the screen, due to the usual mid life eye deterioration. Chair I went for is an office type with adjustable height and tilt, seems comfy so far. Have a great weekend. Rick
I like the camera and screen setup. Is that about how far you would normally have the lens from your work? Is there any chance you could post a pic of how well your camera can zoom in on the movement at a distance you would normally work from. I'm thinking of something similar, which would be well handy as I take a lot of pics as I'm stripping down. I've even got a floor pedal I could rig to work as a trigger for the shutter. Really nicely done!
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
    • Sirius. Thank you for helping others with that information. This is why this forum is so good.
