Shortt–Synchronome clock
Tmuir
The Perth Observatory has in their possession a Shortt–Synchronome clock, this clock used to be the clock that provided the time for Western Australia.
For those that have never heard of it, this is the most accurate pendulum clock ever made. When it was made in the 1920s and 30s it was believed to have an error of 1 second a year, but in 1984 one of these clocks was compared to an atomic clock and found to have an error of only 1 second every 12 years.
It achieves this by having 2 pendulums, one that swings in a vacuum which is the master and via magnetic sensors it sends pulses to a slave clock that displays the time.
I was just wondering is anyone here ever has had the chance to see or touch one of these clocks?
Currently the observatory is looking to get this repaired, I have no involvement in this, but I do know people that are tendering to repair the clock and should they be successful I will be asking if I can atleast come up and see the clock whilst they service it. Just stressing I won't be working on the clock, but to get a chance to see a clock like this serviced would be too good an opportunity to miss.
For those that would like to do some more reading on this clock it has a wiki page.
https://en.wikipedia.org/wiki/Shortt–Synchronome_clock
I have seen them before there are various ones on display in museums in the U.K, I have seen one at the Greenwich Observatory and the science museum has one in its collection and quite surprisingly they do turn up in auctions I have a Christies catalogue for a specialist horology sale in which one is listed.
As for touching one I always heed the signs that say "Do not touch the exhibits":)
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
    • Nickelsilver is right, movement diameter and keyless works ‘fingerprint’ are important for identifying movements. That said, this appears to be a 7 jewel version of the a Revue 30 movement.  A quick search with google turns up parts movements, and individual parts should be quite easy to come by.  Hope that helps, Mark
