Help with the old clock
I set apart this old clock, cleaned it, and now I want to oil it and put it back. Using the photos I made during the disassembly, I reassembled it just to the end. Now I have problem with these two giant springs on the right side. Either they wont get in place, or they just jump out suddenly. Any idea how to put all this back? Thanks.
https://imgur.com/a/KdUUxBa
If the movement is back together and screwed/pinned. You need to make sure the spring is hooked on the arbor then wind it up, when it is nearly fully wound you need to feed the end of the spring over the pillar, which will hold it in place. Repeat with the other. So the spring catches the arbor you might need to pull on the spring part way in so as to take up the slack and the end is tight on the arbor.
Let me know how you are getting on.
The problem is actually how to wind up the springs, in order to put them in the cage. Once they are wind up, it is easy to hook them on arbors (in this case they are the upper supports of the whole clock cage). But they always jump out, and I also have other wheels to put in (at least four of them). I already decided to put the balance wheel last.
At the beginning of the process, the springs are unwound and take a lot of space. It is hard for me to wind them enough so they can be placed in the cage (since the springs are attached to the upper bridge so to say). So, I need to wind them enough to put them both in the cage, and then hooks the end on the arbors. Then they are under tension and that is it. However, once I try to wind the spring, and put them on top of the movement, they jump out.
  • 4 months later...
Hello again,
I have finally time to get back to this old clock (Viktoria 7 jewels). Still, I have no idea where to start and I expected it would be a lot easier (I mainly worked on watches and this thing is huge). I did found the photos I took during the disassembly but they are not of much help (here: https://imgur.com/a/subHhf1)
Did anybody recall any similar clock mechanism whose drawings I could use to put this clock back?
The most difficult part are still the huge springs (especially two of them which are kinda connected). I didn't find a way to put them together them in cage (they always fly get out somehow). Other parts are mostly in good shape and with a proper lubrication should be fine.
Edited by bojan1990
    • All Done, Here are the finished pictures: This one shows the generic "one-size-fits-all" base which accepts the bespoke rings - notice that the parametric movement OD (27.40 mm) automatically prints on the ring 🙂 From another angle: Here is the ring about to go into the base: And finally the base and ring together: Here it is next to a pen for scale: On my system with 20% fill each ring will take about 18 mins to print, but I am sure this could be optimised: Here is the screenshot of the spreadsheet in FreeCAD, you just need to change one value to create the ring in cell C3, (the base doesn't need any changes). I'll upload the files to printables in due course, but here whey are as a fake pdf, please change the .pdf to .zip to make the file worn once downloaded: Modular Movement Holder.pdf Any feedback welcome!
    • I'm going to give that a go next time, thanks for a great idea @rossjackson01 One of my students uses this tool and swears by it https://www.cousinsuk.com/product/wheel-hand-roller-remover-bergeon?code=W1851 which is very like getting two sticks of pegwood under the wheel and rolling them in your fingers so they create a slight prying from underneath motion, I suppose. Maybe bind one end of the two sticks of pegwood so they are like tweezers.
    • Thank you. I spent a lot of time on that.   It never ceases to amaze me that there are so many slight adjustments that can be made to the chronograph mechanism through setting the eccentric studs to get them all to a concerto, like an orchestra with everything in time and to its most optimum. Understanding that setting one stud to the desired effect may throw another out is the fun of working on vintage chronographs. Great pic of the 3133 dart tooth interaction and tilt of the tooth. I love working on 3133s. Slightly better than the 7733 in my opinion and you get a date at 6!
    • Thanks Richard The stem is 0.6mm wide. At least the part that the crown goes onto. Is that enough info to order a new stem and crown and look a pics of the stem so check that the part that goes into the keyless works matches the one I have? Asking out of ignorance! Cheers, Nick
    • Probably Chinese, you can measure the stem you have.
