Hello all!
I have been struggling with the matter of mainspring winders for a while and I want to share some of my experience with Bergeon mainspring winders.
First, there two major types:
the old ones, with a spoke on the arbor (30081):
and the newer ones with a recess on the arbor (Nivarox):
Side by side #6:
to be continued...
Share this post
Link to post
The above are the two major types. From the second type, the Nivarox one, specialized winders emerged, meaning a specific winder for a specific caliber (ETA, Rolex).
From what I learned so far, the barrel and arbor diameters of both 30081 and nivarox sets are the same. The difference is that for the older type, with the hook, one would need to stretch the inner coil of the mainspring for it to accept the hook - when the second one, the Nivarox, don't - the Mainspring just fells in the recess and accepts the little hook in there.
So with the second set you can work on mainsprings with lower inner coil diameters.
But of course, the newer calibers have smaller-diameter mainspring arbors...
to be continued...
Share this post
Link to post
So for a watch enthusiast, working on a modern day 2824, 2892, 7750 is quite exciting. And you get to the point when you want excelence, so you start investing in tools. At some point you hear about Mainspring winders - used in professional environments - and you start drooling (considering the costs). So you start hunting for mainspring winders. First you win some bids on the older Bergeon style and some no-name-Bergeon-style winders. But you realise it's not enough, because there are about 17 sizes and you only have about the 6 smaller ones and few others - you are missing quite a few. Then you realize the difference between the newer ones and the older ones...
Then you decide to brake the piggy-bank and bid on the Nivarox 2795 17 sizes. And you win. And it arrives and you test it on your currently-opened-on-the-bench 2824. And the arbor is too big - you miss-shape the inner-coil  - you almoast have a stroke... :)))
So you start obsessing about them - you see that there are some Bergeon winders specifically for ETA - but you don't have the dough now...
So you start obsessing about what to do to make them work...
to be continued...
Share this post
Link to post
I will speak for the 2824 but the principle applyes to other calibers also.
for the 2824 you need the winder #7 - which has the exterior barrel of 10.8mm. AND you need the arbor to be about 2.5mm in diameter. But in the Nivarox set, the #7 piece has an arbour of 3.5mm.
**As a side note, in the 2795 Nivarox, as you also can see in the table above, there are two identical arbors for each two consecutive barrels. For example the arbors for #3 and #4 is 2.5mm. The arbors for #7 and #8 is 3.5mm. This is important, because you can mess with one of them (wait for it) without risking absolute failure.
So you need a 2.5mm arbor on a 10.8mm barrel for a 2824. So you take the #4 arbor and put it in the #7 barrel.
first problem: there is quite a gap between the 2.5mm arbor and the 3.5mm barrel sot the arbor willform an angle with the barrel.\the second problem: the disc on the #4 arbor is way smaller then the #7 barrel. And with the help of the first problem - the mainspring willescape through that gap.
So, ... to be continued...
Share this post
Link to post
For the first problem I searched the internet and found brass pipes of 0.5mm increment with 0.22mm wall thickness (!).
And I made some sort of bushes to fit the barrels:
For the #7 barrel I would need the 2.5mm-interior/3mm-exterior and the 3mm-interior/3.5mm-exterior:
to be continued...
Edited by matabog
Share this post
Link to post
And for the discs, I disassembled the #3, #5 and #7 arbors and manufactured some larger discs for them. The pictures are self explanatory:
Comparison between the new ant the old sizes:
Share this post
Link to post
Great Post will follow your examples I have had the same issue you encountered. Also I found with the new Bergeon winder sets the gap that accepts the spring when winding was too small and had to file wider.
PS  are the bushes removable so you can use the tool as originally intended if needed.
PPS. Poor design from Bergeon considering the cost
Share this post
Link to post
yes, the bushes are removable. There is no problem if the disc is larger then necessary - plus you have the other arbor (as I mentioned above, you have two identical arbors for each two consecutive barrels - you only modify one of them).
The tool can definitely be used as originally intended with no problem.
Share this post
Link to post
6A817BDC-E7B6-44A6-B42C-AC270CD626E8.thumb.jpeg.e241bf90c87114452e237a338f4be31f.jpegGreat information and thanks for posting. I could not find those arbor diameter sizes anywhere so that is really useful. I had the same problem with no winder for Landeron 48 etc so just started to make one. Waiting for a 1mm carbide end mill to arrive from China to add the hook piece, and a M3 die to finish winding handle. The winder bit is going to be Nivarox style as this is what I saw to copy, but if that does not work the spoke type looks probably easier to make. Not sure if it is going to work, but cannot really see why it should not
Share this post
Link to post
Thanks for your posts. Very enlightening! Mainspring winders are unfortunately a struggle indeed. May I ask where you got the arbor diameters? I’ve been searching Bergeon’s site but couldn’t find the information. I don’t doubt your numbers but I’d like to know the arbor diameters for their movement specific winders as well. Thanks!
Share this post
Link to post
...I measured them :) after I received them. The dimensions are for the Nivaflex version, the ones in the post. The table is a print screen from an excel file I made :)
Edited by matabog
Share this post
Link to post
Thanks! That's what I thought! After all, why should Bergeon provide this information when it could led to reduced sales?! :huh:
Share this post
Link to post
You need to find someone that has the ETA winders set to give you the dimmensions.
What I know from a friend that bought only the 2824 winder - the arbor is 2,5mm. So I suppose the newer winders have smaller-diameter arbors. Which, I suppose, is good for the current calibers, but won't work for the older calibers (it won't catch the maisnpring, and the bigger-arbor winder will have a barrel too big).
So you need to know what you're working on.
I am satisfied with my Nivaflex set, together with the improv's I made on it, because I can use them for both older and newer calibers.
About the left hand arbors... I  use two consecutive barrels, the larger being smaller then the watch barrel - and I right-hand wind it in the smaller barrel and then push it in the bigger barrel. Then, I will finally push it in the watch barrel (I am talking about seikos, citizen and Orients).
p.s. I also have #6 and #7 left hand winders, which are 3 and 3,5mm. But I don't have the 2,5mm arbor... so, depending on the watch arbor diameter, I use the left hand winders or the small barrel-big barrel improv.
Good luck!
Edited by matabog
Share this post
Link to post
Loading...
  • Similar Content
    • By VWatchie
      Some time ago I bought a Bergeon micrometre (and a Seitz jewelling tool) to be able to replace damaged jewels. The micrometre works perfectly down to the exact hundredth of a millimetre but trying to measure my first jewel I bumped into a very unexpected problem; the height adjustable round table fouls the spindle (circled in red).
      I don’t think, or rather I hope, that the micrometre isn’t out of order and can be adjusted so that the spindle does not bump into the table. But searching high and low I just can’t find any documentation or user manual for this type of micrometre. Being a hobbyist having spent a small fortune on these tools, this situation is very frustrating.
      So, the question is, what can I do to adjust my micrometre? As I have no clue what the various parts of the micrometre are named, I have given the various parts in the pictures a letter (in yellow) so that if anyone who knows how do this (and takes pity on me ) more easily can guide me.
      Keeping my fingers crossed. Hard!
    • By Rexxus
      Hello,
      im excited to be part of the community! I’m in the process of buying some of the tools I’ll need to tinker with pocket watches. My goal is to be able to take apart, clean, possibly fix, and reassemble pocket watches.
      I’ve bought a gorgeous pocket watch from a defunked jeweller from the early 1900’s Michigan. I brought it to a 91 year old watch maker and he told me not to start with it. Good advice. He gave me grief in general, hooked me up with some screw drivers, a loop, and a working watch cleaning machine for $20! I’ve bought a pair of tweezers, watch repair kit, some dial protectors, oilers and am looking for the items below. Hoping you can help me out with what to look for and where to find them. Right now I’m using eBay for a lot of tools and want to manage costs.
      1. What 3 chemicals do I need for the watch cleaning machine? It’s not an ultra sonic or whatever, it’s the kind with 3 glass jars. Where should I buy them for shipping to Canada.
      2. What attaches to the rotating arm of the machine to go inside the glass jars? A tiny cage to put all the pieces in? Are they universal or do I need the specific one for this machine?
      3. Oil and grease. I will stick to pocket watches only and will probably buy elign, Waltham, vostok, and any other pocket watches between $0-$40. I don’t want to buy 19 oils at this point. The basics so I can clean and lube a watch without wrecking it. If that means correctly lubricating 90% of it with 3 oils, great. Moebius seems to be the most popular. Which lubes do you recommend? From my research it seems I need 1 grease, 1 high velocity oil, 1 low velocity oil
      4. Mainspring winder. I can’t tell what brand or size I need. It seems 9-15. Are there specific companies that only make pocket watch winders or does Bergeron make them for wrist watches and pocket watches? I assume both so how do I tell a winder from Bergeron works with one of the other as an example. Seller doesn’t always know.
      5. Does anyone have any suggestions for books about learning watch repair?
      6. The watch I have isn’t an elign for example. Its probably a stock movement of the time put into one of his pocket watches. How would I find the technical guide? Are there rules of thumb? Do you just google tech specs in general for each movement?
      7. I was planning on taking pics of my tools and watches to post on here in a different thread. Is that a good idea? What thread is best?
      Thanks a million and have a good night!!!!!
    • By marcoskaiser
      Hello all,
      I just got a K&D mainspring winder very cheap, but the tool is a bit stuck and the spring does not open when the ring is loosened. I would like to clean and oil the spring. Any clues on how to disassemble the winder? I don't want to ruin the threads turning the wrong way or using pliers...
      Thank you!
    • By VWatchie
      I’m considering ordering a couple of Bergeon mainspring winders from CousinsUK, and I really want to get it right as these are expensive tools.
      The way I read it, the specified diameter of each winder is the outer diameter of the winder’s barrel drum. That is, I would need to order a winder having a smaller specified diameter than the inner diameter of the mainspring barrel I’m going to use it with? For example, if the inner diameter of my mainspring drum is 9.80 mm (as is the actual case) a Bergeon No.6 Winder Ø9.80mm would be too large, or just right, no, yes?
    • This always amuses me as a wonderfully ambiguous statement. Lubricated for life? which is how long....????? One wonders if Seiko would provide a free replacement spring and barrel if it were found to be faulty after the warranty period has expired on the grounds that a reasonable lifetime for the watch (and therefore any component contained therein) is significantly more than the normal 1 year warranty period that is usually offered, especially since in practise their watched have been shown to last 50+ years.
    • My company still follows a traditional of giving gifts to employees who reach certain anniversaries with them.  Having been offered a choice (and being who I am) I chose the very traditional choice of a watch.  Only new quartz watches were being offered, so I chose this nice Bulova.  It is on its way.  My father owned an exquisite wind-up Bulova and it was superb. I am curious how the quartz ones compare.
    • Not some actual "hands on" progress on the movment today.  But some more good info collected!  Found this! It certainly clears a few things for me. So it is the same movment as the FHF 96. So I think I let it in this thread. For future rerference on this movment. Hopefully it helps some more ppl.  (hope it is ok to share this)    Another pleasant news. Is HSL has offered to donate a spare movment.  Im humbled of his offer. I offered to pay something for it. But he galantly refuse!  Thank you HSL. It will defenetly help my skills move forward!
    • "Note: I recommend to not disassemble the barrel on the 6R15 movement, because a special material (SPRON 510) mainspring is used link, for which one would not find an exact replacement, and the barrel is sealed and lubricated for life. If there is any issue with the mainspring, replace the barrel complete."   any other watches have this special barrel? lasts how long 100 years?
