Abrasives with Screwhead Polisher
sstakoff
Recently acquired a beautiful screwhead polisher:
The polisher came with two jars of abrasive powder. One is carborundum and the other diamantine. I am looking for some guidance as to which abrasive gets used on which lap and advice on how to charge the lap. There is a steel lap, a brass one and finally a wooden one.  Thanks in advance!
Diamantine and carborundum come in different grit sizes, you'd naturally want coarsest on the steel, medium on the bronze, and finest on the wood. 800 grit for coarse, 1200 or so for the middle, and to finish I like 1 micron diamond paste (about 14000 grit) would be my recommendation. Maybe even a little coarser for the steel if you want. Seems like a big jump at the end but in my experience works well. When I frequently used my similar tool I made up a tin lap to replace the wood. Now I use a tripod tool with 12 micron paper on glass to flatten, and 1 micron diamond on a tin lap. I find it's much faster than the above tool.
Thank you. I will check the grit sizes when I get home tonight. Assume you mix the powder with oil -  If so, any recommendations o=n type of oil?
I've never heard the reason behind it but knowledgeable and experienced polishers have always told me it's better to use a good vegetable oil than a mineral oil. Colza is a good one. Nothing disastrous is going to happen if you use a thin machine oil though.
On the coarse laps the oil/abrasive can be rather wet, but on the final lap you want to rub it on and in with a clean finger or cloth, leaving a distinct layer but it should almost be dry. If it's wet the abrasive will clump together and ball up giving fine scratches along with the polish.
    Very good!    what do you do if the screw slot is buggered up?
   I use synthinic (sp) oil,   veg. oil can mold.   the viscosity to use is the real question.  vin
When you get to using it you have to make 110% sure you've cleaned the screw perfectly when going from one lap to the next. Otherwise you'll contaminate the lap and it will need to be resurfaced. Artist's gum eraser and old rodico do pretty well, finish with pithwood and a friendly solvent like isopropyl alcohol. It's tedious but less tedious than redoing the lap.
Depends, if the slot isn't beveled then simply polishing the head takes care of any raised burrs and makes the head look tidy again. You could run a screwhead file through it if really going for perfection.
On beveled heads a very fine cut square escapement file works well. Like a 6 cut or 8 cut if you have it. The file finish blends visually with the polished head and looks polished. A square degussit stone can also work but they often are too rounded at the corners. To keep the file centered in the slot leave the screw in the polishing tool, it will rotate slightly as needed keeping the file on track. If not using the lathe type polisher you can rest the screw in a bench block so it's supported by the head and the screw will align itself with the file.
   good show;  to de burr the slot.  I use a hone stone.  they are available in small triangle  or  small flat,  course or fine .  oil,  water or dry  vin.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
