Abrasives with Screwhead Polisher
sstakoff
Recently acquired a beautiful screwhead polisher:
The polisher came with two jars of abrasive powder. One is carborundum and the other diamantine. I am looking for some guidance as to which abrasive gets used on which lap and advice on how to charge the lap. There is a steel lap, a brass one and finally a wooden one.  Thanks in advance!
Diamantine and carborundum come in different grit sizes, you'd naturally want coarsest on the steel, medium on the bronze, and finest on the wood. 800 grit for coarse, 1200 or so for the middle, and to finish I like 1 micron diamond paste (about 14000 grit) would be my recommendation. Maybe even a little coarser for the steel if you want. Seems like a big jump at the end but in my experience works well. When I frequently used my similar tool I made up a tin lap to replace the wood. Now I use a tripod tool with 12 micron paper on glass to flatten, and 1 micron diamond on a tin lap. I find it's much faster than the above tool.
Thank you. I will check the grit sizes when I get home tonight. Assume you mix the powder with oil -  If so, any recommendations o=n type of oil?
I've never heard the reason behind it but knowledgeable and experienced polishers have always told me it's better to use a good vegetable oil than a mineral oil. Colza is a good one. Nothing disastrous is going to happen if you use a thin machine oil though.
On the coarse laps the oil/abrasive can be rather wet, but on the final lap you want to rub it on and in with a clean finger or cloth, leaving a distinct layer but it should almost be dry. If it's wet the abrasive will clump together and ball up giving fine scratches along with the polish.
    Very good!    what do you do if the screw slot is buggered up?
   I use synthinic (sp) oil,   veg. oil can mold.   the viscosity to use is the real question.  vin
When you get to using it you have to make 110% sure you've cleaned the screw perfectly when going from one lap to the next. Otherwise you'll contaminate the lap and it will need to be resurfaced. Artist's gum eraser and old rodico do pretty well, finish with pithwood and a friendly solvent like isopropyl alcohol. It's tedious but less tedious than redoing the lap.
Depends, if the slot isn't beveled then simply polishing the head takes care of any raised burrs and makes the head look tidy again. You could run a screwhead file through it if really going for perfection.
On beveled heads a very fine cut square escapement file works well. Like a 6 cut or 8 cut if you have it. The file finish blends visually with the polished head and looks polished. A square degussit stone can also work but they often are too rounded at the corners. To keep the file centered in the slot leave the screw in the polishing tool, it will rotate slightly as needed keeping the file on track. If not using the lathe type polisher you can rest the screw in a bench block so it's supported by the head and the screw will align itself with the file.
   good show;  to de burr the slot.  I use a hone stone.  they are available in small triangle  or  small flat,  course or fine .  oil,  water or dry  vin.
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
