  • Similar Content
    • By AccidentalWatchmaker
      Hi all,
      I'm currently building a custom watch with an ETA 2892-2 movement. The movement is from an old Brietling. I managed to fix it and was working perfectly. I was in the process of putting it all together, was attaching the second hand and it suddenly stopped. I believe I may have used too much force. However, I have taken the watch apart again (about the 12th time!). I notice that when I move the hacking spring it stops as it should, but when I return it to the position that would usually allow the movement to move again it doesn't. I assumed I'd knocked something out of alignment, but to add to the confusion if I give the escape wheel the slightest nudge it continues ticking. It's baffling me.
      Anyone have any ideas?
      Best,
      Dan
    • By AdamC
      Hello, I've been struggling for two evenings now to fit the train bridge on this ETA 2832. Every time it looks like all pivots are aligned through the jewel holes and I begin tightening the bridge, the wheels begin locking up. On closer examination, it looks to me like the 4th wheel is not seating flush against the centre tube as shown in one of my photos. I believe this because the pinion on the 4th wheel is higher than that of the escape wheel, and equally about the same measurement out between the 4th wheel and the 3rd wheel pinion, which is lower. It also looks like the 4th wheel is fouling under the train bridge.
      In your opinion, would my suspicion be correct or should the 4th wheel's pinion rest approx. 1 to 1.5mm above the flange of the centre tube. If it should be flush, do you have any tips to seating it as such? I have obviously tried carefully wriggling it under light pressure without luck. I've added an extra photo showing the placed wheels during disassembly to give some context.
      Thanks in advance
    • By Mark
      Join me as I strip down, service and review this Chinese ETA 2892-A2 clone. Seagull ST1812 watch movement. There was a couple of issues to deal with but altogether a fairly impressive movement for the price.
    • By arkobugg
      Hello Mates!
      Im working on an ETA 2783, and suspect that the canon pinion is to tight against the lower wheel.
      So I have to make it a little bit more loose...
      Has anybody done this befor?
      And how it the best way to do this?
      Thanks   A
      ETA type of Center Wheel/Cannon Pinion
    • Dear All,   My nice Bergeon screwdriver set was chipped after few watch services, was looking for a sharpening kit to repair them, but I soon realized I own a Lansky knife sharpening kit, so I pop the screwdriver blade out and give it a try, the results are very promising, see the photos, it's easy to use and versatile, comes with different stones, if I like, I can even use the ceramic stone to give it a high polish, and I can always use it to sharpen my folding knives, what do you think? Love to hear them.   Darak 16A49BD8-DF55-4F10-BB5D-983DE0C1380C.MOV
    • Hello everyone, I am looking for a sapphire crystal back for an OMEGA Seamaster (212.30.41.20.01.003). Do you know where I can find one ? Thank you in advance.
    • Hi and welcome Brian,  I am confident someone on this forum will come along and put you right concerning grandpa's watch. There is nothing "unfixable" if you go about it the right way and in the right order. Good luck I wish you every success.
    • Hello, my name is Brian Young and I am new to watch repair.  I recently inherited a 1911 Illinois pocket watch that was working.  WAS.  I dropped it on the tile floor in the kitchen.  Now, I need to repair it, as it was my grandfather's watch and I cannot be the reason the watch has stopped working.  I do not repair watches, do not know the "lingo", and don't own an awesome set of tools.  I am the "street urchin" in this performance of Oliver.  Any help or encouragement you can extend to me would be most appreciated.  I am fearless, and will take the watch apart, if needed.  I would rather have someone who knows what they are doing handle the repairs.  Let me know if I can fill in any missing information.  Thank you for allowing me to crash your party.  Love and light, Brian.
    • Take it easy around that wiring, one thing I did think of after I posted is that some of the old wiring and indeed that rheostat may well contain asbestos. It will be safe enough unless you start chopping it about. I would grab yourself a triac speed controller and bin the rheostat and its associated wiring. There may be some suppressor capacitors that might need changing (although judging by the age of the machine, possibly not) and when the thing is running I suspect it will blast interference all over the radio spectrum, and buzz all over the local radio stations, but probably not enough to travel next door and annoy the neighbors.
