Back to being a member
Being a mod is a thankless task. I helped mod a forum on toy steam engines for around 10 years, and although a small number of members realise just how much you do, many see you as 'the forum police' there to ruin everyone's fun, so fully understand stepping back to being just a member.
Thanks for the work you did during your time as a mod
Thanks JDM, I've watched you deal  unmercifully with spammers, and applauded from my chair. Although I found that I didn't agree with some of your approaches, they where the lesser part of what an admin does, and your constant attention to the forum helped it quite a bit.
Admin is a thankless job, and it's not often obvious what goes on until it's not happening anymore. Hope the other admins can take up the slack.
Thanks Again!
    • Snap! I recently finished my Gruen 510 movement - though the case for mine is in a rather sad state; I'm going to try re-plating it (in nickel, it's not a gold one).   Re. the screws, I got a few of the one gram mixed batches from ebay. I've only needed a couple of screws for things so far, both rare, minuscule types - but both in the mix, after enough time sorting through them! The ones such as normal bridge screws are quite common in those lots.
