Seth Thomas Alarm clock
Mattaphysics
So I sniped this Seth Thomas Alarm clock for day cheaper than I could ever imagine. The only problem was faulty shipping... The glass broke, plus the original paint is peeling off like a horrible sunburn.
I must say it's my first clock purchase and I love it. It's jewelled, probably mass produced, but it keeps perfect time... Seller said it was broke but the only problem is the alarm won't work. When I turn it now it won't click, the first time it did but when the alarm came to strike it just unwound and did nothing.
Now it just won't wind up period. I did figure out how to work the alarm before you ask that.... So I'm not sure what is wrong I took it apart which was easy enough... Putting it back in it's case is another story completely. So any ideas?7494abe9c2fdd7db7e15c97a9f1cfdd1.jpgec8877ee14e771edd044122a35443458.jpg69732c08c137e0f791290fb99ae50bd7.jpgcdada1a7b1429cc084246413ea5930ce.jpg45dcc9495e30dd2e800d7be950ef935e.jpg
Sent from my Z956 using Tapatalk
It could do in a pinch if it fits, but you really want something with a thicker handle, as you want to let it spin slowly in your hand to let down the spring and a pin vice may be hard to hold to let it spin slowly in your hand.
The safest way is screw the key on and let it down by hand, by releasing the click in stages. That way it won’t slip.  Using a pin vice could be a problem if it tends to slacken off you will have no control and damage might happen.
Alarm work on this movement is the same as most on these small movements. It works like this. The alarm spring has power.
Black arrow part is held by red arrow part. When blue arrow wheel drops into the green arrow groove the red arrow part moves away from black arrow part allowing the alarm to work. I have shown the part that drops into place by yellow arrow.
Do I had trouble removing the hands but got em. I took it apart cleaned it and... I screwed the hair spring up somehow! Where can I get one? I've tried searching but am unsure what it is I should search for. Oh I'm just up to my ears in crap I need to find and get. But it seems like it's something wrong with the Barrell or the star wheel/ striking train. It doesn't want to wind or something like that. Not sure
You will need the cal number for any of the parts. Are you sure you haven't mixed the barrels, arbors, clicks or any of the winding up parts. There is no strike train. What you have is an alarm works which consists of barrel, star looking wheel and hammer.
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
