Watchmaker collets, Maintenance.
maclerche
4 hours ago, jdrichard said:
I have used the edge of a screwdriver very carefully on the threads, where there is lots of dirt and a fake metal cleaning pad does not work.
It works beautiful on threads. Green kitchen pad (no sponge) at the supermarket. Cousins also sells them in big sizes.
Bigger collets (5c) I spin the in the lathe and polish them with a red (medium) scotch-brite pad. Inside as well if I can get in there. Then I spray with aerosol Precision oil- sold for micrometers etc. it just sprays on and leaves a light film as it dries. Will not affect tolerances.
If the back side taper is rusty, I polish that by hand with the red pad. It is as critical as the bore so be careful. Any burrs get knocked down with a stone.
Threads are easily cleaned with a wire “tooth” brush. Stainless bristles are fine. But you can use brass. Spray threads with the oil too.
Some of the 5c collets have an internal thread for a work stop. These I clean with a bottle brush. Smaller bottle brushes can be used to clean inside the collets too. Small bores can be cleaned with brushes for cleaning baby straws etc. but lab supply places have tons of sizes and materials. You can also cut a slot in a dowel and slide the piece of red pad in there to polish the id of collets.
Edited by Tudor
The external surfaces of a collet are easily cleaned up, however the real issue (at least for watchmaker sized ones) is corrosion in the bore.  Obviously very difficult to get at mechanically.  You could use an appropriate sized bit of brass wire as a lap but then there's the potential to start changing the collet dimension or bell mouthing it.   Some of the rust removal solutions work really well, I would try a soak in them.  They should remove the rust and only and on the inside and out.
With the rust removed, the best idea is to take steps to prevent it.  Rust requires oxygen and water.   A great deal of the water that causes rust comes from condensate.   Getting a dehumidifier will make the biggest difference, and keep the room a constant temperature.  Most condensate falls of the the air when there is a temperature change  -i.e. dew.  The idea is to keep well away from the dew point. The other thing is keep all tools covered, in drawers etc.  It minimizes the amount of air around the tool and hence how much condensate there can be.  Keping things oiled can help.  Oil doesn't protect so much from direct water like condensate, but it does provide a temporary barrier from the air, air that contains both water and oxygen.
Last thought, the volume of iron oxide is many times that of steel, so if there is just a bit of rust on something, don't despair.  If the rust is light, you likely won't even be able to measure a dimension change
Edited by measuretwice
Just my 5 cents as a good oil to stop rust.
Many years ago I bought a bottle of Camellia Oil to stop my Japanese woodworking saws from rusting.
It is a very light oil that doesn't leave the item sticky.
The japanese used to use it for protecting their swords first and then when the swordsmiths turned to making woodworking tools it was used on these high quality tools.
I now use this oil on anything precision that I want to protect from rust.
This is the stuff
https://www.kriscutlery.com/other-weapons/camellia-oil-for-knves-swords-and-tools
Of course this only helps you after you have cleaned the items.
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
