Hairspring Frustration
Pip
I know it’s me. I know it’s something I need to conquer. I always seem to struggle getting a nicely concentric hairspring when sitting on a balance to sit nicely and not bunch up the coils when I install the balance. Sometimes they sit beautifully, sometime not, and I’m annoyed with myself for not knowing why. Anyone able to point me in the right general direction? I know HS are a book or two on their own but this keeps happening and is driving me crackers. (HS and watch demagged and clean and dry).
Help me General Kenobi, you’re my only hope...
7befd83fedcdfb43dd5b01920111f015.jpg&key=d5e54073aeda0fcfd895537965d87b72c68832720de89363c99a04991f72d3fd
ddef808be4484db2f9b326ef75231843.png&key=370375df4b9af618697ae75e162cb90712082e9fc33b134b658bccaa7e4e95c6
Are these pics of the same balance wheel?
If the balance in the first pic (the one from below) is sitting with its pivot in the hole and the second is the same balance then I think the problem is with your technique in installing the balance wheel. Perhaps you could elaborate more on how you get the balance in place?
I personally prefer to hold the edge of the balance and balance cock in my tweezers when installing the balance wheel as I find I have more control. Most people tend to let the balance dangle while only holding the cock in the tweezers.
Anilv
Anilv
Yes, same balance wheel. It’s technique that I’m asking for help with Anilv so I’ll try again with yours. Currently I’m in the dangling club and I can struggle to get the impulse engaged a bit.
The first pic shows a hairspring & balance in good condition. The second pic shows a hairspring that is either contaminated, magnetised or just damaged.Where the last coil attaches to the end stud has been bent inwards see pic. I would remove clean with a de- greaser, de-magnatise and install again before any manipulations.
It's the same balance, the pics were taken about 5 minutes apart. Only thing that had changed was to move the regulator back towards neutral as it was pointed a little to one side.
It has been cleaned a couple of times (in lighter fluid and hung on a post with the HS dangling to dry) and demagged several. Maybe I need to buy a compass to check if my demagging is working.
Edited by Pip
40 minutes ago, Pip said:
(---) Maybe I need to buy a compass to check if my demagging is working.
1
Do you have an iPad or an iPhone? In that case, I'd recommend the "LEPSI - Watch MAGNETISM" App. I think it's available for Android as well but don't know how well it would work on your hardware (of course). I demonstrate it on my iPad here.
Magnetism does not make more difficult to fit a balance.
Also, I recommend that you use petroleum ether or other purified chemical instead of lighter fluid, and do not let the balance dangle on the hairspring.
Take another pic with the balance sitting on top of the balance cock... If the gathering is damaged the pic won't be as nice as the earlier one.
The problem with the dangling balance method is that it's a bit fiddly for watches like this Seiko.  It's fine for Swiss handwinds where the balance pretty much drops straight in but on watches where the balance is partially covered by a bridge the potential to snag the balance is higher.
Anilv
I would say that the lighter fluid is just not enough to clean hairspring properly. At least rinse it in acetone and try again.
anilv is right, the dangling balance method is not suitable for watches where the balance is somehow covered. My method is to hold the cock and balance together with tweezers and put them where they have to be (approximately). After that I can manipulate with the cock only and put everything in place. For other watches the dangling method works just fine.
I downloaded the app @VWatchie and it's showing no magnetism is present. I will remove, take photo's, and reinstall tonight. I need to get this one sorted soon as I have donated it as a prize for a competition on another forum I'm involved with and want to donate a cleaned and serviced watch that's running well. It was in a right state before, I'm happy with all my work other than the balance installation. Thanks for everyone's help so far :biggrin:
Are there any reasons other than oil and magnetism that can foul the coils?
@Pip When you have the time, it would be nice to see a picture of the watch itself! I actually have a similar situation with a Poljot 2614.2H movement. The Penultimate HS coil sticks to the utmost coil. I have demagnetized it, and I've just serviced it. I really can't detect any oil looking at the coils in my stereomicroscope but I guess it must be there :huh: (noticed I had overoiled the balance end stone, ouch!)
22 minutes ago, VWatchie said:
The Penultimate HS coil sticks to the utmost coil. I have demagnetized it, and I've just serviced it. I really can't detect any oil looking at the coils in my stereomicroscope but I guess it must be there!
That's because the hairspring is distorted.
It takes a lot of magnetism or grease to make coils actually stick, even if these reasons are usually blamed first.
   you need to read up or "video up" in the "entry shape"  of the lead into the main part of the hair spring.  its in all the books AND  if you have a "time grapher" (sp) it will tell ypi when thw shape "is best".  vin
Edited by vinn3
typo
That's interesting because it doesn't look distorted. It actually looks just fine. I can take an oiler and gently separate the coils, and they stay separated until it starts to run, but sometimes, it can tick for a week or two before the utmost coils stick together again. What would be the remedy if not a contamination but indeed distortion?
With manipulation. But if it's as you say then I don't know why it gets stuck.
Manipulation is definitely beyond my current skill level. I'll clean it again so that I can rule out contamination for sure and demagnetize the balance separately in a plastic bag. Thanks!
Edited by VWatchie
Anilv
Here’s a photo I just took.
While not quite perfect it’s plenty fine for a Seiko 5 I would think and I’ve done some manipulation but not enough to improve on this much if at all.
Interestingly I just turned it over and then back again and it’s now sat like this which is nowhere near as good.
And then a very quick manipulation and it’s to this
Here you go. This is before I started servicing it.
Annoyingly I didn’t take a pic that showed the balance and HS before disassembly. Must remember to do that in future.
Pip, there is a checklist regarding hairsprings in regular watch service. I will not write it again you should do that first.
But if it is surely clean and demagnetized then i would check the end curve is following the regulator pin path. It looks like the end curve or the HS attachment point, or the start of the end curve is distorted making the HS off center.
Edited by jdm
Please don't include pictures in quoting
52 minutes ago, nickelsilver said:
It's either really magnetized or contaminated. How are you demagnetizing?
No, that's not the reason. Seiko hairsprings are extremely easy to get distorted, and equally difficult to correct. read below:
With my small blue electrical demagnitizer. You know the standard type from china. Seems to work ok. I've downloaded the Lepsi Mag app that was recommended by @VWatchieand it's showing no magnetism present.
I think that I need to up my HS cleaning game. I can't seen anything untoward on it but that doesn't mean it isn't there.
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
