Rolex ID
Can someone help me please with the type number of this Rolex movement. It belongs to a friend and has been "got at" many years ago. The balance and escapement seem OK and  I have fixed the "Click"  and  need a new hairspring with collett and bead. Then I could hopefully service and finish the job. Any help or ideas would be very much appreciated. Thanks and best regards, Mike.
imageproxy.php?img=&key=77f0dcc5ac0f9d5bIMG_2686.thumb.PNG.35d371d544ad0aee306f8850ddbae73a.PNGIMG_2685.thumb.PNG.d71c93fa7e1cbb9487df53d948f0a6a2.PNG
Edited by jdm
I have a Breitling Navitimer coming in for service next week. Two people "in the trade" have told me not to go near it. Why Not ? can someone tell me please. I have serviced three chrono`s in the last 15 months , and recently a 1950`s  Zenith. The Zenith took me 2 days to re-assemble it,  me not being a watchmaker but a Jobber.!!
1 hour ago, jnash said:
Off the top off my head, I know a few watchmakers that don't because they have issues with the small chrono hands get damaged and are hard to find.
Thank you for that information jnash, I will be extra extra careful. I think I will need  one of the pushers as well. Maybe I have got something I can mod and fit otherwise I will need to find a spare.
Sent from my ONEPLUS A6003 using Tapatalk
Thank you very much from Mike.
Silly trade people ignore them jump in and do it anyway. The silly trade people probably have an issue with where exactly do we buy Breitling replacement parts?  It's not just the movement parts what about the casing parts? This is one of the major problems in watch repair now doesn't matter if you are the best watchmaker in the universe if there's a damaged part that needs to be replaced and you can't get it, you will have a unhappy customer.
Then chronographs this came up couple weeks ago in the discussion here somewhere. A lot of the chronograph hands are driven on their meant to be replaced. But they're also meant to be serviced by someone who has parts.
WOW! I have a Breitling coming in soon. I surely will have to be most careful !! I have no spare parts and will I think need one pusher. So when it arrives, here goes !.
  • Similar Content
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
