Oooops I did it again
transporter
Well once again my local online market place had another clock that caught my eye, it measures 45cm x 35cm and is slate and possibly marble, it’s got an Ansonia chiming movement installed. Closer inspection shows some knocks  and some kind of painted repair marks.
the movement looks like is has had a WD40 spray so a full strip etc to come, the brocok type escapement ( think that’s what it is called ) needs repair as can be seen in the photos, this I can see is going to be abit of a project
It is a strike movement. Parts are available for these type of clocks. The composition of the plates are quite soft so wear is a big thing, the biggest fault with these American clocks are the springs and they are so strong they force the movement to work. The steel is also soft. Looks like a chimpanzee has had a go at the pallets.
About the springs, you can buy clamps for these springs. Do not try to assemble the movement with the springs unwound you will have a wrestling match on your hands.
Tip
Clocks with one key hole = Timepiece
Clocks with two key holes = Strike
Clocks with three key holes = Chime
There are exceptions.
Thanks for the tips, especially about the springs, as for the pallets, i know someone else here had some made of made them for their project, I might bite the bullet and buy a scrapper movement for spares aswell as trying make some myself.
im hunting a site called antique Ansonia clocks, but so far haven’t found mine, does anyone know what the name/cal this movement is please?
imageproxy.php?img=&key=77f0dcc5ac0f9d5b
I thought the pallets pins were held in with shellac, looks like tar, probably a bit of extra weight to slow the clock down a tad lol....The slate will clean up OK.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
