omega case-back
I have an omega triple date repair....the issue is that the month wheel is jammed and will not advance....if the date is advanced via one click of the crown it will stop at 31..the only way at this point to advance it to 01 is via the crown while setting the time...now the issue I am having at time with...getting the pressure ring case back off...for some reason on older pieces I have not had an issue...on this one yes!..any advice on how to remove it would be most welcome...there is no where on the  case back indicating where to insert a case knife....my horotec case back remover was no help in this situation either...thanks...
1 hour ago, rattandsonwatchmakers said:
it is smooth all the way around....I considered a screw case-back...no notches to fit a tool I tried Bergeon suction grips attached to my case back remover...did not budge.....I am at a loss....
There is no screw back without notches or ridges. Surprising that Omega made a snap back for this type, it has to be removed like that.
What's interesting from the picture is notice how the Words on the back the case exactly line up top to bottom? Usually With screw on back's it's really hard to get them in exact position. Then I had the thought that perhaps this is not legit except? So googling gives a different answer I've looked at three identical cases as far as the back lining up the words etc. So as it appears to be a legitimate Omega case I'll ask the other watchmaker at work he specializes in Omega's.
    • Showing state of hairspring on receipt, backplate & 'dished' wheel.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?       Have you seen this video, he shows how to determine where the indents go ?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
