Making spade drills
Fred
Hi everyone,
Yesterday I made a spade drill for the first time following the instructions on the Chicago watchmaking school books, now I'm wondering if its possible to make a 0.10mm drill. Has anyone ever tried making one?
Thanks alot
I've made a 0.10mm spade in carbide for repivoting a small escape wheel pinion. Robert Porter wrote a nice pamphlet on making spade drills in steel or carbide with plans to make a simple indexing jig and a slightly modified pin vice which is available from AWCI.
A handy thing about spade drills is they can be ground "waisted" or narrowing from cutting edge back. In the event of breakage while drilling this makes it fairly easy to remove the broken drill from the hole.
Thanks for the replies everyone.
Nickelsilver and Praezis, do you anneal the steel before making the drill? I'm trying to use blued steel, is it possible to make a drill from it or am I just wasting my time?
Thanks a lot everyone
Blue steel isn't hard enough to use for cutting steel. For a small drill start with O1 or similar tool steel. You can rough it out prior to heat treatment or not. Harden, then temper to a light straw color. Now you can grind the drill form, being very careful not to overheat and draw the temper further.
Carbide is handy for small drills as the heat issue disappears but you need very good diamond wheels and laps.
On 8/7/2018 at 11:08 AM, Tudor said:
I suggest buying them.
Solid carbide sold in packs of ten, because you WILL break a few. Be careful because you can easily get a carbide “splinter” when the bit jams into your finger and snaps off...
Are you talking about carbide twist drills?
Here is how I make my custom drills:  http://jamesriser.com/Machinery/MakingCustomDrills/Spades.html
By starting with HHS I can skip the hardening process and possibly warping when using O-1.  I prefer to step down from a standard diameter to the required drill diameter.  This makes for a stronger drill and one easier to mount in the lathe or drill press.
Jim
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
