Making spade drills
Fred
Hi everyone,
Yesterday I made a spade drill for the first time following the instructions on the Chicago watchmaking school books, now I'm wondering if its possible to make a 0.10mm drill. Has anyone ever tried making one?
Thanks alot
I've made a 0.10mm spade in carbide for repivoting a small escape wheel pinion. Robert Porter wrote a nice pamphlet on making spade drills in steel or carbide with plans to make a simple indexing jig and a slightly modified pin vice which is available from AWCI.
A handy thing about spade drills is they can be ground "waisted" or narrowing from cutting edge back. In the event of breakage while drilling this makes it fairly easy to remove the broken drill from the hole.
Thanks for the replies everyone.
Nickelsilver and Praezis, do you anneal the steel before making the drill? I'm trying to use blued steel, is it possible to make a drill from it or am I just wasting my time?
Thanks a lot everyone
Blue steel isn't hard enough to use for cutting steel. For a small drill start with O1 or similar tool steel. You can rough it out prior to heat treatment or not. Harden, then temper to a light straw color. Now you can grind the drill form, being very careful not to overheat and draw the temper further.
Carbide is handy for small drills as the heat issue disappears but you need very good diamond wheels and laps.
On 8/7/2018 at 11:08 AM, Tudor said:
I suggest buying them.
Solid carbide sold in packs of ten, because you WILL break a few. Be careful because you can easily get a carbide “splinter” when the bit jams into your finger and snaps off...
Are you talking about carbide twist drills?
Here is how I make my custom drills:  http://jamesriser.com/Machinery/MakingCustomDrills/Spades.html
By starting with HHS I can skip the hardening process and possibly warping when using O-1.  I prefer to step down from a standard diameter to the required drill diameter.  This makes for a stronger drill and one easier to mount in the lathe or drill press.
Jim
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
