Hello Everyone!
I'm new to the forum but not new to watches. I've been encouraged to say "HI!" to everyone and post a photo of my everyday wearer (actually, I have 2).
The first is an 1968 Omega Constellation that I built completely custom out of NOS parts.
The second is a 1974 Rolex 1601 with a custom dial and end-links.
Hope you guys/gals like them!
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
