What a Poising tool shouldn't look like
Tmuir
Buying a second hand poising tool off ebay is always a risk if they don't give you good photos, but this seller has and people are still bidding on it.
The seller has stated its functional, but it isn't.
Wonder if paypal would side with the buyer if they try and return it as the text says its functional but the photos clearly show it isn't, but it still has a number of bidders.
https://www.ebay.com.au/itm/VINTAGE-USA-MADE-C-E-MARSHALL-WATCHMAKERS-POISING-TOOL-ORIGINAL-STORAGE-BOX/142863713952?hash=item21435746a0:g:pXEAAOSwC6xbRny2
Guess if you are just wanting it for a display and don't plan to use it, it could clean up nice..........
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
