What kind of tool is this?
bojan1990
If you look at the bergeon tool in the video the "fingers" pull back, no center screw. Makes sense. The tool in the pics presses in the center, almost certainly a clock hand puller (or small gears etc. where pressing on a shaft while pulling around it makes sense).
I found on eBay a somewhat similar device. The seller claims it is a hand puller which makes sense to me.
I am a bit confused on the screwing bits since if you are pulling hands, you probably don't need the screwing function. I guess it's more gentle if you do.
I am guessing it's a hand puller.
