Mostly Russians, and few Japanese and Swiss
VWatchie
Careful examination of the stub of "gold" to the left might give some clues. It looks as though there was a metal tab attached to that, and floating on that plastic washer, but that may now be missing.
If you had another mech to compare, obviously that would be a help.
Maybe try a small copper wire screwed to that left hand screw and placed on top of the plastic washer, then refit the battery and see if it springs to life.
Also take a look at this pic. of a similar mechanism.
I suspect that Timpsons are fitting the battery incorrectly.
The left hand screw/gold plate, needs careful cleaning, and the right hand tab needs fitting *UNDER* the battery, but above the plastic washer, and insulated in such a way that it doesn't short out the cell at the edge, so perhaps it just needs bent correctly to be recessed in at the right hand side of the battery holder to avoid contact with the edge of the battery. In other words the +ve of the battery looks to be connected to the left hand contact, and the -ve appears to be connected to the right hand contact (avoiding shorting things out in the process). The cell is an SR920SW, which are cheap as chips.
On ‎1‎/‎5‎/‎2019 at 6:58 AM, BUSAKAZ said:
Hi Andy thanks for the advice I’ll give it a go when I get a min and report back.
Thanks Kaz
Hi all an update, after completely stripping the movement it was completely covered in battery gunk so put the parts in the cleaner and new battery and all is well :thumbsu:
I've now been wearing my red and black radio room Amphibia/Albatros (first picture of the first post in this thread) for exactly one month since I last regulated it (Vostok cal. 2409 manual). December 27th it was 29.5 seconds late, and today it's 32.5 seconds late. It has lost three seconds in a month! It's been a long time since I wore a quartz watch, but as I remember it, those weren't much better than that over time. Of course, it largely depends on how the watch is worn, stored and wound, but nevertheless, I'm "blown away"! Who said Russians weren't up to the Swiss!? ;)
    • Snap! I recently finished my Gruen 510 movement - though the case for mine is in a rather sad state; I'm going to try re-plating it (in nickel, it's not a gold one).   Re. the screws, I got a few of the one gram mixed batches from ebay. I've only needed a couple of screws for things so far, both rare, minuscule types - but both in the mix, after enough time sorting through them! The ones such as normal bridge screws are quite common in those lots.
